Old 05-27-2020, 10:13 PM   #1
Default Wind direction and speed
Was planning to boat tommorrow on Winni, as the temps are still high, mid 80's.
The winds however are predicted to be about 14 mph with gusts to almost 18 mph. The winds will be from the SW.
Will these winds produce a rough chop and possible white-caps?
Thanks for your feedback !
Old 05-27-2020, 10:28 PM   #2
Yes.
Enjoy!
Old 05-27-2020, 10:48 PM   #3
Not in the north!
Old 05-28-2020, 05:00 AM   #4
webmaster
Moderator
webmaster's Avatar
ishoot308 (05-28-2020)
Old 05-28-2020, 08:04 AM   #5
Default Check cams
Check out the cams at Anchor Marine and this site, available at the home page of this site.
Old 05-28-2020, 08:16 AM   #6
That's a great site!!
Thanks!
lakeadoodle (05-28-2020)
Old 05-28-2020, 11:21 AM   #7
Barney Bear
Default Surf's Up 🌊
We often refer to this helpful site before venturing out to our place on East Bear Island. Thanks, Don! 🐻
Old 05-28-2020, 11:48 AM   #8
FlyingScot
Not in the north!
I'm in the north--Moultonborough Bay, not too far from you--and I sail, so I am always looking at the wind speed reports. Sadly, they are often incorrect, even on a real time basis. I have not used Sailflow as Don has posted, but I have used Windfinder Pro, which appears virtual identical, so I assume it's the same data source. I write this off to an insufficient number of stations, and too much extrapolation on the part of the software.
Any thoughts from either weatherheads or other northerners on this?
Old 05-28-2020, 03:35 PM   #9
Another site that uses the same input data:
https://www.ventusky.com/?p=43.575;-...;10&l=wind-10m
The Weather Underground Wundermap shows the input stations that vary all over the place.
https://www.wunderground.com/wunderm....54&lon=-71.37
Old 05-29-2020, 01:21 PM   #10
Merrymeeting
Merrymeeting's Avatar
One of the best sites for consistent, accurate, wind forecasts is www.windfinder.com
Living on the east side of the lake, I've found that using the gust numbers rather than the average wind speed gives me a better indication of what to expect for the day.
Old 05-29-2020, 08:44 PM   #11
FlyingScot
That's the one I've been using with real time reports that often differ from what I'm looking at from my dock. Most recent was last week where the report was 9mph, but the water was perfectly flat
This page was generated in 0.09226 seconds
