Old 07-16-2015, 06:41 PM   #1
Default Help With This Harness!
Hi,
Can someone explain how to hook this harness up to my pontoon? I was expecting it to have just the hooks at the end, to clip onto the toons, but there's another foot or so of rope with a hoop at the end of each hook.
Old 07-16-2015, 07:18 PM   #2
Dad sold the C * C
Without seeing the whole thing, I would say put the loop thru the U bolts on the back of the boat and clip the loop. It looks like plastic tubing to reduce rope chaffing.
Old 07-16-2015, 08:53 PM   #3
Post From What Can be Seen...
I'd say you got it right. The main part of the harness is very thick, so it would require hooking the loop to divide the strain at the ends.
If one used the loop (only), a great deal of strain would be placed on that single polyethylene-line splice. The hook's attachment doesn't appear to be designed for taking all the strain, either.
Old 07-17-2015, 02:19 PM   #4
I agree... This in my opinion is really not the best design I have seen... To be honest growing up we always had great luck with a harness like this:
http://www.airhead.com/boating/ropes...eel-cable.html
Old 07-16-2015, 07:32 PM   #5
That's what I was thinking, but I'm not confident the rope/knots will fit through pontoon hoop. It's the same on two ends, by the way, with a quick connect at the third end.
Old 07-16-2015, 07:49 PM   #6
Resident 2B
Resident 2B's Avatar
Did it come with instructions?
R2B
Old 07-16-2015, 08:07 PM   #7
Umm... It might have, but the kiddos tossed the packaging!
Old 07-16-2015, 08:14 PM   #8
"Simply clip it to your stern eyes." http://www.airhead.com/watersports/t...w-harness.html
Old 07-16-2015, 10:54 PM   #9
Resident 2B
These instruction are not helpful at all. I agree with the poster that suggested putting the loops through the eyes, if they fit. If they do not fit, the only option is to hook it directly with the metal hooks. I believe it is designed for two connections, one on each side of the motor or outdrive. Good luck and stay safe!
R2B
Old 07-17-2015, 01:34 PM   #10
Unhelpful (I think?) convo with Airhead (from top up):
Yes you can let it drag or tie it up. Whatever works best for you.
Hi!
**** If I use the hooks, what do I do with the extra foot of rope at the ends that will drag in the water?
> Hi Shawn,
> You can attach it with the hooks or with the loops. It has 2 options for different types of boats. So use whichever works best for you.
Old 07-17-2015, 02:50 PM   #11
I'm thinking of returning this and just using the ski bar, which worked very well last week.
This page was generated in 0.09820 seconds
