Old 05-05-2014, 01:32 PM   #1
persamp
Default Moving sailing dinghy from Sunapee to Winni?
I am looking for advice on how to move a 15 ft sailing dinghy (hull wt ~200 lbs) from Sunapee to Winnipesaukee. Boat is on a dolly, but I do not have a trailer. I have a vehicle that can tow it, but no trailer. Any suggestions as to where I might borrow / rent a suitable trailer? Other suggestions? Thanks
persamp is offline   Reply With Quote
The Following User Says Thank You to persamp For This Useful Post:
Old 05-05-2014, 10:31 PM   #2
RLW
RLW's Avatar
Smile
persamp, I just noticed that you are fairly new to posting on the forum and glad you have joined us. Have fun and enjoy the Winni Forum while making many new friends.
I'm sure someone will come up with a solution for you and get your sailing vessel to where you want it.
persamp (05-11-2014)
Old 05-06-2014, 12:35 AM   #3
Uhaul rents trailers.
persamp (05-06-2014)
Old 05-06-2014, 07:46 AM   #4
dickiej
Post an ad on craigslist.....you will probably be pleasantly surprised by the responses you get.
The Following User Says Thank You to dickiej For This Useful Post:
Old 05-06-2014, 11:22 AM   #5
As previously suggested uhaul has a selection of trailers.
Although I am not positive if they have on the will fit your needs.
Craigslist as previously suggest is another idea, you might find someone to help you out.
My suggestion would be to contact a marina to two to see if they can help you out... Or even better their are a few Mobile marine mechanic out fits that might be able to help you as well...
Old 05-06-2014, 11:57 AM   #6
I used to haul a 16ft canoe on an 8ft kit-trailer I got from Harbor freight. Your dolly would probably center nicely on the flat-bed section. Use lots of tie-downs and chock the dolly's wheels or remove them.
These cost about $250 plus wood for deck and sides (if desired. No welding required just a couple wrenches or sockets. Add a 'flag bar' with streamers across the transom and you are good to go. Best not to use this configuration at night unless you add extra lights and/or reflectors.
Old 05-07-2014, 09:39 PM   #7
nhcatrider
Could always try to round up a 4 place snowmobile trailer. Mine is 27 feet long, certainly big enough for the task and it will hold the weight without a problem.
The Following User Says Thank You to nhcatrider For This Useful Post:
persamp (05-08-2014)
Old 05-08-2014, 09:51 AM   #8
http://nh.craigslist.org/rvs/4410547654.html
Not mine, or anyone I know.
persamp (05-09-2014)
Old 05-11-2014, 08:34 AM   #9
persamp
Default Thanks
Thanks to everyone for your suggestions. In the end, I posted to u Ship and had Hillsgrove Hauling pick up and deliver my boat. It was a good process and everything went smoothly. Can't wait to get out on the water!
This page was generated in 0.13016 seconds
