-   -   Moving sailing dinghy from Sunapee to Winni? (https://www.winnipesaukee.com/forums/showthread.php?t=17458)
persamp 05-05-2014 01:32 PM
I am looking for advice on how to move a 15 ft sailing dinghy (hull wt ~200 lbs) from Sunapee to Winnipesaukee. Boat is on a dolly, but I do not have a trailer. I have a vehicle that can tow it, but no trailer. Any suggestions as to where I might borrow / rent a suitable trailer? Other suggestions? Thanks
RLW 05-05-2014 10:31 PM
http://i44.tinypic.com/1499wms.gif persamp, I just noticed that you are fairly new to posting on the forum and glad you have joined us. Have fun and enjoy the Winni Forum while making many new friends.
I'm sure someone will come up with a solution for you and get your sailing vessel to where you want it.:)
http://i54.tinypic.com/2e56yqf.gif
ITD 05-06-2014 12:35 AM
Uhaul rents trailers.
dickiej 05-06-2014 07:46 AM
Post an ad on craigslist.....you will probably be pleasantly surprised by the responses you get.
LIforrelaxin 05-06-2014 11:22 AM
As previously suggested uhaul has a selection of trailers.
Although I am not positive if they have on the will fit your needs.
Craigslist as previously suggest is another idea, you might find someone to help you out.
My suggestion would be to contact a marina to two to see if they can help you out... Or even better their are a few Mobile marine mechanic out fits that might be able to help you as well...
Kamper 05-06-2014 11:57 AM
I used to haul a 16ft canoe on an 8ft kit-trailer I got from Harbor freight. Your dolly would probably center nicely on the flat-bed section. Use lots of tie-downs and chock the dolly's wheels or remove them.
These cost about $250 plus wood for deck and sides (if desired. No welding required just a couple wrenches or sockets. Add a 'flag bar' with streamers across the transom and you are good to go. Best not to use this configuration at night unless you add extra lights and/or reflectors.
nhcatrider 05-07-2014 09:39 PM
Could always try to round up a 4 place snowmobile trailer. Mine is 27 feet long, certainly big enough for the task and it will hold the weight without a problem.
Kamper 05-08-2014 09:51 AM
http://nh.craigslist.org/rvs/4410547654.html
Not mine, or anyone I know.
persamp 05-11-2014 08:34 AM
Thanks to everyone for your suggestions. In the end, I posted to u Ship and had Hillsgrove Hauling pick up and deliver my boat. It was a good process and everything went smoothly. Can't wait to get out on the water!
