Old 03-20-2008, 04:16 PM   #1
WINNOCTURN
WINNOCTURN's Avatar
Exclamation New Web Address Moultonboro Snowmobile Club
We have change the Club Web Address From moultonborosmc.com to moultonborosmc.org
NEW ADDRESS: http://www.moultonborosmc.org/
There are a few glitches to be worked out. The number one is when you go through the different pages and hit the HOME tab it knocks you off the site. If you use the “Back” icon on the tool bar you can get to “HOME. We should have it fixed shortly. We are also trying to set the old site to redirect you to the new site.
George
WINNOCTURN
Old 03-20-2008, 04:22 PM   #2
wifi
wifi's Avatar
I see you have changed providers, but why the domain too?? (Just curious, no finger pointing)
Old 03-20-2008, 04:31 PM   #3
brk-lnt
brk-lnt's Avatar
Quick fix:
Copy your "index.html" file to also be "index.htm".
Easiest way to to do the redirect would be to just change the DNS for your old site to point to the IP address of the new server, and setup the new server so that it knows about both domains. The process varies slightly based on how exactly it's hosted, but it's not that hard in either case.
Old 03-20-2008, 04:54 PM   #4
WINNOCTURN
WINNOCTURN's Avatar
Thumbs up Thanks for the tip
Originally Posted by brk-lnt View Post
Quick fix:
Thanks for the tip. I have forwared it to our Web Administrator.
George
Old 03-20-2008, 05:11 PM   #5
WINNOCTURN
WINNOCTURN's Avatar
Thumbs down Support Problem
Site went down 3 weeks ago because of some "software" changes? After several days of support people give wrong information and the inability to clearly understand what they were saying we did find some one who knew what they were talking about. The problem had nothing to do with what the original support people were telling us.
The change from .com to .org may have some thing to do with our changing our status to a non-profit organization?
George
Old 03-20-2008, 05:46 PM   #6
brk-lnt
brk-lnt's Avatar
George
Likely, but just FYI, that change was not specifically necessary, you could have kept the old domain name.
This page was generated in 0.20539 seconds
