05-27-2004, 09:19 PM | #1 |
Auxiliary anchor recommendation
I'm asking for some thoughts on a secondary anchor for the "Mee-n-Mac". It's primary purpose would be to tie the stern down so it doesn't swing with the wind when in close quarters with other boats (who've done likewise). Think fair weather rafting more so than foul weather e-gear. I don't need anything as robust as the primary anchor but then again having a back-up isn't such a bad idea (and would surely be my choice if on the ocean, just not sure where I'd store the thing). What have you used for an auxiliary anchor that worked ? ... that didn't work ?? What would you recommend for a 24 ft, 5000 lb boat ???
Mee'n'Mac "Never attribute to malice that which can be explained by simple stupidity or ignorance. The latter are a lot more common than the former." - RAH Last edited by Mee-n-Mac; 05-28-2004 at 07:29 AM. Reason: bad typing, worse proof-reading |
05-27-2004, 09:28 PM | #2 |
glad to help
How about my wife and a couple of cement blocks!!!!!!
Seriously, I just have two fluke type anchors and normally drop the bow, back up to get enough (can't think of the right term) play in the line to hold properly, go back a little more, toss anchor two off the stern and pull forward to set it. Helps to be into the wind, if other boats allow. |
05-28-2004, 09:33 AM | #3 |
I just bought myself an aluminum fortress (fluke) for my primary. Excellent holding power with less the weight. Being that it is lighter than my "other" fluke that I've been using for years, I went up one size so it can double as a storm anchor. Now I use my old anchor for the stern since I use that less frequently.
06-04-2004, 02:05 PM | #4 |
Thx people
Seems the responses are pretty much what I was thinking. Another Danforth type anchor is the ticket. Just gotta find a place to store it. I guess I could get some holder mounted to the pulpit rail.
p.s. "upthesaukee" - Good to know your wife doesn't frequent the forum. If I'm wrong re: this, then I congratulate you on your new, celibate, llifestyle
06-04-2004, 02:11 PM | #5 |
-Mac, you got it, another Danforth type is all you need. I use an 8 pounder with 3/8" line for tying down the stern and it works great. You don't usually need as much as your main anchor because the load is not nearly as much.
Ken |
06-04-2004, 02:45 PM | #6 |
Fortress Anchor
we use one of these anchors. my wife found a nice pouch (made by fortress for the specific size anchor) to put it in when we're not using it. you have to disassemble it to get it in the bag, but once done, it's very easy to store. it takes all of five minutes to put it together.
"You ain't gonna learn what you don't want to know" |
06-04-2004, 08:42 PM | #7 |
No, my wife doesn't frequent the forum, but she does read the upthesaukee mail....OOOOOOOOOOPS. Thank god the dog house is screened in. Actually she is used to the comments and usually manages to get even. Enjoy the season, maybe see you on the lake.
06-07-2004, 05:02 PM | #8 |
2nd anchor
Buy a 2nd anchor rated for your size boat. Not worth the aggravation of not having one large enough.
I've seen many boats pull anchor at the sand bar bacause they had to small an anchor to do the job. Nothing worse than having that happen with boats all around you and in jepordy of being hit. |
