12-15-2020, 04:29 PM | #1 |
Water from the lake in the winter
I'm thinking of converting the cottage to a year round residence and I'm interested if anyone has experience with a self draining water system like this one... https://www.cottagewatersupply.com/w...water-systems/
I know I could always run a heat-line water pipe but think a drainback would be more efficient (if it works). I'm also getting tired of fighting and replacing the jet pump every few years and a submerged pump looks appealing. Digging a well is not an option as I would not be able to bury the lines given my topography and a railroad track. I'd also be adding a multi-stage filtration and UV light as well (lots of good advice on the forums for this topic). Thoughts? Recommended installers? Thanks. |
The Following User Says Thank You to DanP For This Useful Post: | ||
lagoon (12-15-2020) |
12-15-2020, 05:35 PM | #2 |
It looks like a useful design. My only thought would be that on the pump end of things there ought to be some sort of screen/filter to keep crud out of the water sent up. Even with that, conceivably regular (annual?) maintenance might involve cleaning the diverter valves of any sediment or other contaminant. I wonder if the owner of that railroad track would have any problem with the water line running beneath the rails. What's the story on that?
12-15-2020, 06:27 PM | #3 |
If you can't go under the rail road tracks, how are you going over?
I've seen some year round lake water enter the lake a couple feet down and goes under the ice. That system going through the ice and draining back still looks kind of vulnerable long term year round. I'm getting a well drilled in January/February, I can't wait. |
12-15-2020, 07:11 PM | #4 | |
12-15-2020, 08:50 PM | #5 |
The wildly fluctuating lake level may effect where the heated section is. If you run an aquatherm and the line is in open water that would not be a problem. Allowing the line to freeze into the ice might be a problem in the spring when the ice shifts around. If you have a pump problem in the winter that submersible can't be accessed and you will be without water. You must be on the South side of Meredith bay. Why not drill a well lakeside?
12-16-2020, 05:37 AM | #6 | |
The Following User Says Thank You to tis For This Useful Post: | ||
ApS (12-16-2020) |
12-16-2020, 08:26 PM | #7 |
Drilling a well is an option but i don't think I could easily get the pipe run back to the house below the frost line. I think it would also be a challenge to get the drilling equipment over the railroad tracks (would require a crane). Lots of rocks, a big berm and not a lot of land between the house and the railroad track. The house is also doesn't have a basement. That's why the self-draining approach looks appealing. With the circulator running for the dock, ice wouldn't be an issue if I place it properly.
Thanks all for the replies. |
