08-21-2017, 10:26 AM | #1 |
Outboard issue ?
I've been having an issue with my Johnson 90HP two-stroke.
Motor idles fine. No hesitation going from wake speed, to full throttle, really quick ! Issue only relates to moving at wake-speed, at which point the engine seems to vibrate. Once I go past 'wake-speed', the engine smooths out and runs fine! Other than this issue, this has been a great engine ! Thoughts about this issue ? |
08-23-2017, 07:50 AM | #2 |
If you have a stainless steel prop, it may be a bit loose on the shaft and that would absolutely cause this issue. See if prop can slide fore and aft or rotate a bit on the prop shaft.
