01-26-2005, 11:54 AM | #1 |
Web Cam Help?
I love the lakes area web cams and I want to set one up at our camp in Wolfeboro. Is there a website that offers a tutorial on how to set one up? I need to find some simple instructions outlining step by step what I need as far as equipment and procedure. Any help out there?
01-26-2005, 12:09 PM | #2 |
How To From The Masters
Check out this Webcam Thread
Don't forget to share it with us! Good luck. Welcome to Winnipesaukee.com! Last edited by Rattlesnake Gal; 01-26-2005 at 12:14 PM. |
01-26-2005, 12:27 PM | #3 |
Moderator
You can also find lots and lots of info through Google. The Webcam Zone is a good place to start.
01-26-2005, 02:40 PM | #4 |
What about the ISP?
Thanks for your help. These links are very helpful. But a couple questions I have not found answers to yet:
1) Who is a reliable ISP for the wolfeboro area, any suggestions? I found access4less.com is only $5.95 per month. 2) If I use a network camera do i need a high speed connection or will the camera automatically dial up every 10 (or whatever time setting I select) minutes and upload a picture? |
01-26-2005, 03:31 PM | #5 | |
Moderator
Network cameras can be attached directly to an external modem and work in much the same way, just without a computer. The Rattlesnake CAM is setup like that. Using a computer has some advantages but does require more hardware. I can dial in to the WeirsCAM/Anchor Marine CAM computer using PCAnywhere and make adjustments just like I was sitting there. The direct camera/modem setup gives you less control but seems to work fine for many Webcams. |
01-26-2005, 09:03 PM | #6 |
Be careful to pick an ISP that has an access number within the area you can call without extra charges. I picked RCN as my dial-up ISP because they have a Laconia access number. Laconia is in my Verizon "Unlimited Local Calling" service area.
I called into my network camera and changed the timing to call in every 5 minutes so I could get time lapse video of the ice forming. |
