Old 04-14-2023, 10:30 AM   #1
songkrai
Default Price Cost of Oil Change
What was the cost of last oil change ? And where.
Yes, depends on 4, 6, 8 cylinder.
Any discounts floating around?
Old 04-14-2023, 12:01 PM   #2
Walmart Auto Care Center in Tilton and Plymouth stores still have the Pit Crew -$19.88 oil and filter change but it is traditional oil and not synthetic. Synthetic oil and filter change at Walmart starts at about $35, and you can upgrade to the better quality gold Fram filter as opposed to the bronze Fram filter.
Is best to get there at 7-am, seven days/weeks, to beat the waiting line.
Old 04-14-2023, 08:55 PM   #3
$33
My garage at home
Old 04-14-2023, 08:57 PM   #4
garysanfran
$33
My garage at home
Where do you recycle the oil?
Gary
~~~~_/) ~~~
Old 04-15-2023, 01:29 PM   #5
If you're looking for cheap FLL knows all those places.
Old 04-15-2023, 01:32 PM   #6
If you buy oil from Walmart they will take your old oil. They usually have pretty good prices on Mobil 1.
Old 04-15-2023, 01:41 PM   #7
Oil retailers must accept your old oil. It's the law.
LIforrelaxin (04-20-2023)
Old 04-15-2023, 02:30 PM   #8
John Mercier
Many town sheds (road maintenance) and even Meredith Truck have used oil burners that heat their buildings with.
We sell motor oil; but I do not know of any NH RSA that requires us to accept used back... and we never have.
Old 04-16-2023, 07:59 AM   #9
I remember 40 some odd years ago they use to oil the dirt roads with it.
Old 04-16-2023, 10:48 AM   #10
Me too, keeps the dust down on unpaved roads.
Old 04-16-2023, 11:07 AM   #11
Years ago I worked for a large construction material supplier with over 400 vehicles. Changing the engine oil in one truck sometimes takes 8 to 10 gallons.
We put waste oil heaters in the maintenance garages for winter heat but ended up running them overnight during the summer. In the construction industry, summer is when we generated the most used oil.
Old 04-16-2023, 03:14 PM   #12
John Mercier
Post the RSA.
I have been in retail for close to the last 16 years...
We have always sold oil and never accepted used oil.
I find it hard to believe that no one in our management would be aware of such a statute.
Old 04-16-2023, 03:29 PM   #13
Default Not Required In NH
https://www.cga.ct.gov/2000/rpt/2000-R-0185.htm
Old 04-16-2023, 03:52 PM   #14
John Mercier
So NH doesn't actually have such a law.
Old 04-16-2023, 04:19 PM   #15
longislander
Looks like used oil ... not sellers of oil.
F. Used oil for recycle rules apply to:
1) Generators;
2) Transporters;
3) Marketers; and
4) Burners of used oil.
G. “Do-it-yourself (DIY) used oil” means oil that is derived from households, such as used oil generated by individuals through the maintenance of their personal, non-business vehicles. DIY used oil generators (i.e., homeowners) are exempt from the requirements of the Hazardous Waste Rules. Anyone who collects DIY used oil becomes a generator of “Used Oil for Recycle” and is subject to the generator requirements in Env-Hw 807.06.
https://www.des.nh.gov/sites/g/files...quirements.pdf
https://www.des.nh.gov/sites/g/files...env-hw-800.pdf
RE: previous post to RSA 147: B12 https://www.cga.ct.gov/2000/rpt/2000-R-0185.htm
https://www.gencourt.state.nh.us/rsa...OC-X-147-B.htm
longislander is offline   Reply With Quote
Old 04-16-2023, 08:42 PM   #16
Great they charge you when you buy the oil and setup grants to help towns collect it. Then the towns like Tuftonboro turn around and charge the do it yourselfers to get rid of the oil.
Old 04-16-2023, 10:27 PM   #17
I think there are some changes going on. Gas stations (remember when they were service stations?) will generally collect oil and more frequently over time, use it for heating. BUT, now others will buy it from them and either use it for heat or sell it to somebody like Wentworth Greenhouses in Rollinsford. They in turn, developed a business to re-refine the used oil and use some for heat and some gets sold for other purposes. That operation was in turn sold to Clean Harbors. I recall when it first opened, they were re-refining hundreds of 1,000's of gallons a year. The next closest similar operation was in Ohio, doing thousands of barrels a year. I expect there are more of these operations in place now--my info is several years old, from when I was in a related state oversight position.
DotRat (04-17-2023)
Old 04-16-2023, 11:31 PM   #18
John Mercier
I believe the grants are for infrastructure... not operational costs.
Old 04-17-2023, 06:34 AM   #19
I had my own auto repair shop for many years and heated with used oil.
I started out accepting oil from others but that turned out to be a big mistake because DIYers tend to mix other fluids, like antifreeze, brake fluid, and other non-petroleum products, that would cause problems with the burner.
Old 04-19-2023, 09:45 AM   #20
DPatnaude
Looks like most transfer stations around the lake accept used motor oil:
https://www.des.nh.gov/sites/g/files...t-used-oil.pdf
DPatnaude is offline   Reply With Quote
Old 04-19-2023, 02:10 PM   #21
loony
loony's Avatar
$23.00 at home
costco/Kirkland 2-5qt 0w-20w full synthetic oil jugs for $30 plus ~$8 oil filter. I can change the oil in two cars in less time it takes to drive one to the shop. I drop off the used oil next time I go to the transfer & recycle station
$33
My garage at home
Old 04-19-2023, 04:32 PM   #22
Embarrassed to say what I paid last week at Cantin Chev for my truck
Old 04-19-2023, 07:50 PM   #23
I have a full size GMC. It takes 8 quarts of synthetic oil so any oil and filter change would be at least $100.
Old 04-19-2023, 08:01 PM   #24
Higher!
Old 04-20-2023, 06:42 AM   #25
Higher!
I had my own repair business, retired 3 years ago. I would get $100 then for a Mobil 1 oil & filter change. So I guess inflation has takin it's toll.
I just replaced an alternator in my daughters car, cost me $400, I use to pay $250. You can get them cheaper online but if you need it right away you pay a premium.
I still change my own oil & filter with Mobil 1, costs me about $50.
Old 04-20-2023, 07:26 AM   #26
Neko
The GMC dealer that services my truck charges $79.95 for a oil change and tire rotation.
Neko is offline   Reply With Quote
Old 04-20-2023, 08:48 AM   #27
That's more what I would expect, and many places like that will still vacuum too.
Old 04-20-2023, 10:27 AM   #28
That's cheap if it's a full size truck that takes 8 quarts, they are making next to nothing with rotating the tires too? GM dealers use Dexos, which is more money than Mobil 1.
Mine is a 2018 4x4 with a 5.3 liter engine, takes 8 quarts of full synthetic not synthetic blend. The older models only took 5 quarts of oil.
Old 04-20-2023, 11:36 AM   #29
If you purchase your tires at either the Tilton or Plymouth Walmart Tire & Lube Center, they will rotate your tires for free, forever, so I always get that done with their oil change. Walmart can get that wackadoozie sized tire designed for an old boat trailer, too.
Is best to get there at 7-am, seven days/week, to beat their waiting line.
Old 04-20-2023, 11:46 AM   #30
I take my truck to the dealer because it is the cheapest alternative... usually around 70$ although its possible the price has increased since my last oil change in the fall......
While the dealerships charge an arm and a leg for a quart of oil, they build price they pay and use in their shops is quite different.....
I myself have a full size GM truck, with 8 qt. capacity.... The dealership that I use is still be best option... I have talked with various garages and you Jiffy lubes and because of the extra capacity their charges jump quickly...
Old 04-20-2023, 06:38 PM   #31
Skippermark
Skippermark's Avatar
Dexos is an approval rating (specification) that was developed by GM. It’s not an actual a brand. Mobil 1 is Dexos approved.
Skippermark is offline   Reply With Quote
The Following User Says Thank You to Skippermark For This Useful Post:
Biggd (04-21-2023)
Old 04-21-2023, 06:56 AM   #32
I didn't know that? Being an independent shop owner, I've only used Mobil 1 for the past 40 years for all my synthetic oil changes.
I just bought a 5qt jug of Mobil 1 yesterday, $29. Sometimes I buy it at Costco's, if it's on sale it's cheaper. Add 3 more quarts and a quality oil filter and I'm up to $50 to $60. I have a friend that lets me use his lift so I'm not crawling around on the ground.
Like I said, if you're paying $70 at the dealer you're getting a bargain.
Old 04-21-2023, 10:30 AM   #33
I have an old school oil pit (concrete) but with all of the plastic shrouds and nonsense on new cars, I bring the cars to a local independent shop! I use the pit for tractors etc still.
Old 04-21-2023, 11:54 AM   #34
Skippermark
I didn’t know about it either, but my son is an auto tech and told me about it, and sure enough when I looked up Mobile 1, Valvoline, and a few other brands, they all had that Dexos logo on them.
I imagine there are some of their oils that aren’t certified, but they’re probably for older cars.
I guess it’s kind of like from the “old” days when I was younger and oil had ratings of SF, SG and the like.
Mobile 1 is a great oil. They really started the push to synthetic, and even today other brands just don’t have the popularity of it.
Old 04-21-2023, 12:56 PM   #35
Arrow Mobile Popularized, but Didn't Devolop Synthetic Oils
Back in the1950s, you'd be aware of a synthetic oil made by Castrol. Castrol "R" for racing had a strong odor of castor oil, from which it was first synthesized.in Britain.
https://www.motorsportmagazine.com/a.../55/castrol-r/
Valvoline was on the right track with their conventional oil, offering low viscosities of 5, 10, and 20 weights in the early 1970s.
Red Line synthetics arrived on the racing scene in 1980, but had only a low level of market penetration. Their claim to be 100% American-made brings out the patriot in us. .Their large range of products can be admired, and can be ordered through Amazon:
https://www.amazon.com/s?k=redline+m...l_9enw7937ot_b
A primer on synthetic oils:
https://gmb.net/blog/synthetic-vs-co...%20the%20years.
Old 04-21-2023, 01:35 PM   #36
Oil pits are great. Don’t see them enough
Old 04-21-2023, 03:11 PM   #37
GM does label their synthetic oil, Dexos. You can buy the Dexos brand oil but it's more expensive than Mobil 1.
Old 04-21-2023, 04:09 PM   #38
Skippermark
Thanks for the links. Now I'll have some good reading to do before bed tonight.
My son has a couple older muscle cars and only puts Red Line in them, but he said it's not API approved though the quality exceeds their standards.
I had never heard of it until he told me about it.
Old 05-17-2023, 04:35 AM   #39
Default LN Engineering, LLC..."Tech Tuesday"
I receive regular emails from a Porsche development website, located in California. As one might expect, everything "LN Engineering, LLC", sends is top-notch.
Their opinions on modern oil usage caught my eye. We don't hear of "break-in oil" nowadays, but with today's modern engines, the importance of break-in oils has actually risen.
Here's a partial quote with synthetic oil highlighted:
"...Both the cylinder walls and piston ring faces would wear into each other, hence where the term breaking in an engine came from. Cylinder bores in modern engines are for the most part all plateau honed and use harder carbon steel piston rings, many of which use coatings like CrN (chromium nitride) to provide increased durability. This results in less wear during break-in but can also mean engines can take longer to break-in and can be more sensitive to tuning issues during initial run-in. Likewise using the wrong oil during this period can extend the amount of time it takes to seal up the piston rings or even prevent them from seating at all. That is why a break in oil is used and synthetics or any oils with friction modifiers should not be used during the break-in period.
"As the engine oil is often referred to as the gasket between the piston ring and the cylinder bore, what oil is used for break-in and afterwards is critical. We all know never to use a synthetic or semi-synthetic oil in a new engine, however using any engine oil with friction modifiers can also negatively affect the ability of the piston rings to break-in, resulting in poor ring seal and increased blow-by. Remember, we need there to be some wear between the rings and cylinder bores to allow everything to seal up properly during this period."
Their recommendation for all engines is a motor oil with the brand name of "Driven".
Forty years ago, engine rebuilders were advised not to use STP when re-assembling their engines. Because of the above quote, I suspect even the small amount of STP used would mix with conventional break-in oil, thereby affecting the length of time piston rings would take to "wear-in".
I disregarded that advice when rebuilding my occasional Porsche 911 engine (among others), thinking the benefits would outweigh any negatives. Fortunately, unbeknownst to me, everything worked out well.
LN Engineering also brought up the oil measurement markings on Porsche dipsticks. It turns out, Porsche revised their dipstick lengths, even providing replacements.
When I rebuilt my first 911 engine, it was to replace valve guides, seals, and gaskets because of excess oil leaks and oil consumption. Little did I know until having the exact same problems, that dipstick had broken off at the end about ¾-inch!
Old 05-17-2023, 05:50 AM   #40
I pay $75 for full synthetic in my 4Runner every 5k miles. The oil and filter itself would be somewhere around $50, so it basically costs me $25 to simultaneously save two hours of my life and provide me an hour to read in a quiet, kid-free setting. Win-win!
Old 05-17-2023, 07:08 AM   #41
garysanfran
Default Valvoline...
I have used Valvoline both in Laconia and San Francisco because of the convenience and they seem to service the vehicle well checking everything from battery, radiator, tire pressure, etc.
However, I have no knowledge of what kind of oils they use. I use their synthetic brand.
Any feedback on Valvoline? They weren't cheap. I think my 2002 Toyota Tacoma, synthetic, with their "discount" coupon was about $119.
My Tacoma was awoken from it's outdoor winter sleep last week. Put the battery in. Whamo...Started right up, as though it had never been stored. Takes me longer to recover from a nap
Gary
~~~~_/) ~~~
Old 05-17-2023, 09:19 AM   #42
The same synthetic, 5-qt oil & filter change, plus check/top fluids and tire air pressure would cost about $55 at the Walmart in Plymouth or Tilton. The Gilford Walmart does not do any car service. For an extra five bucks you can upgrade their Fram oil filter from bronze to gold for a longer lasting filter.
If you bought the tires at Walmart, then Walmart will rotate for no charge, otherwise it is $2.50/tire.
Before driving away suggest you check everything; windshield info sticker, tires, tire air caps, dip stick, engine oil cap to make sure its all good.
Old 09-12-2023, 07:58 AM   #43
Well yesterday I paid $145 for an oil change at local shop I have used for a few years. Prior oil change there was $105. So that's a price jump that crosses a line. I'll be going back to doing my own again. Walmart here I come!
Old 09-12-2023, 08:48 AM   #44
Thumbs up
I always used Mobil 1, either from Walmart or Costco when it was on sale. Costco now has their own full synthetic oil at half the price of Mobil 1.
My Chevy truck takes 8 qts, I just bought 2-5qt bottles for $30. So my next oil change will cost me $35. Too bad there are no Costco's in the Lakes Region!
Old 09-12-2023, 09:39 AM   #45
tummyman
I used to do mine as well, but stopped once they switched over to these insert type filters instead of the prior can type. The inserts are just so messy. Wish I could find a replacement that was the old type.
Old 09-12-2023, 09:47 AM   #46
With the introduction of synthetic oils the need to change one’s oil frequently as we once did decreases. Since the 70’s i have been every 5k miles. Easy to remember and allowed me to take three vehicles over 200k. Today, the wife’s car gets charged one a year with the inspection sticker. My truck, twice. Low mileage driving. My kid the wrench buys his oil at Costco when it’s on sale. Best price around
Old 09-12-2023, 10:28 AM   #47
Yes mobile 1 in 5qt jugs at Walmart is a good price, agree. Prices of goods and services now a days is crazy
Not sure where we are going in this country but at somepoint it's not going to sustain itself and the fall is going to hurt .
pondguy (09-12-2023)
Old 09-12-2023, 10:45 AM   #48
In my opinion, many will just change their lifestyle. Personal, we are on a fixed income. With the cost of living skyrocketing over the past three years we have changed. We did eat out four to five days a week. Now it’s two. Getaways reduced. Always bargain shopping with food and clothing. We did plan ahead so our expenses are minimal.
The cost of services are extremely high with little chance of dropping due to high energy and labor costs.
With that said, health is good, family is good. And living in the safest state in the Union helps (knock on wood)
Biggd (09-12-2023)
Old 09-12-2023, 11:03 AM   #49
John Mercier
It is mostly labor.
What your are bulk buying at a Costco, the shops/dealers are bulk buying in either 55 gallon drums or pumped into a large storage tank from a tanker.
You will find that it various around the country... so what we are experiencing is somewhat different than what they are.
Old 09-12-2023, 11:07 AM   #50
Pretty much the same as you. Cut backs and reduced going out. Oil changes will add to that. I hate to use the word cheap but I find myself actually putting things back in stores simply because I won't pay the price they ask for the product even though I could afford it. Just can't justify some stuff.
Old 09-12-2023, 11:14 AM   #51
It is mostly labor.
Full synthetic at $3 per quart is pretty cheap. When I left the business 3 1/2 years ago, I was paying that for synthetic blend in bulk.
The growing number of trucks and SUV's that have shields under the engine make oil changes slower thus requiring an increased labor charge.
Years ago, I could change oil and filter, check all the tires and top off all the fluids in 15 minutes on a lift. Some of the SUV's take that just to remove the shields, German vehicles esp..
Old 09-12-2023, 11:19 AM   #52
pondguy
pondguy's Avatar
I prefer to call it frugal..
Old 09-12-2023, 11:55 AM   #53
Surprisingly, Mobil 1 really hasn't gone up much in the past 15 years. There's just more competition, more companies making and selling synthetic oils at cheaper prices now. I've been using Mobil 1 for 50 years, when it was the only synthetic oil on the market.
I always bought Mobil 1 for my shop at Costco's. When they had it on sale it was cheaper than Walmart so I would load up on the sale price.
I'm fortunate to have a Costco a mile away from me in Waltham ma.
Old 09-12-2023, 01:58 PM   #54
My son refers to it as “cheap bastard”
Old 09-12-2023, 05:02 PM   #55
Lol. When he's our age he will be one
Old 09-12-2023, 06:03 PM   #56
John Mercier
Frugal is when someone does it themselves.
Cheap is when they expect someone else to do it for less.
The Following 2 Users Say Thank You to John Mercier For This Useful Post:
TheRoBoat (09-12-2023), TheTimeTraveler (09-12-2023)
Old 12-22-2023, 09:50 AM   #57
TheProfessor
4 cylinder Toyota.
$120.00.
Synthetic.
Local mechanic/shop.
Old 12-22-2023, 10:07 AM   #58
Originally Posted by TheProfessor View Post
4 cylinder Toyota.
$120.00.
Synthetic.
Does that include tire rotation? Fair dealer price if it does
Old 12-22-2023, 10:54 AM   #59
Price to do it myself with a 5-qt Castrol Edge, for engines over 75-k miles, $25.98, plus Fram tough guard oil filter, $$7.17, plus rotate tires, $0.00 ...... total $33.15 ..... and I probably get better oil and a better filter.
Rotating tires requires a good floor jack and at least one good jack stand.
Plus you get the experience of working on your car outside in the winter cold out in the driveway ...... .
Old 12-23-2023, 08:38 AM   #60
Default German Motorsport
Occasionally have a coupon in the LaDaSun for $49.95 oil change. A bargain considering they use euro spec Castrol oil. Most European cars take 6 or more quarts, with the Porsche dry sump taking 7 or 8.
They even check all your fluids, and visual inspection underneath your chassis and under the hood! I think it is a bargain!
I can tell you horror stories of my own when going to places like Jiffy Lube, Quick Lane, and Valvoline Speedy Express.
For non-European cars, I recommend Neil's Laconia Garage.
Old 12-23-2023, 09:24 AM   #61
If you have a spare tire you can rotate your tires using one jack.
Old 12-23-2023, 12:02 PM   #62
As a retired mechanic, I still change my own oil. I always used Mobil 1 but with price increases I'm going with a cheaper synthetic.
I bought two 5qt containers of Kirkland synthetic oil at Costco for $30, $3 a qt! My GMC truck takes 8 qts, so that's about a $35 oil and filter change for me. My wife's car only takes 5 qts.
Old 04-12-2024, 08:20 AM   #63
Lightbulb Why Old Vehicles Are Better...
Such is so, but radial tires are "rotated" front-to-back. Bias tires are to be "rotated" in an "x" pattern. Also, don't use an old spare. (Say, older than five years).
A note just came up to read the ULAs (legal issues) for your new vehicle; however, I suspect only a few of us will be interested in your new vehicle's "limitations".
https://youtu.be/A_DmgjTfwD4?si=4ymuc5M0_6K-uSqN
Old 04-12-2024, 08:56 AM   #64
Skippermark
Because of so many changes in the past few years to vehicle types and tire design, there's no longer a "one size fits all" answer for rotating tires. Things like drive train, 4 wheel or all wheel, front or real wheel drive, size of tires and directional or non directional all play a role in how they should be rotated.
ApS is totally correct in that you don't want to start adding a spare to the rotation if it has never been done before. Having one tire with a different amount of tread ware is not a good thing. That's usually why reputable shops won't replace one bad tire with a new one. All 4 usually need to be replaced.
Michelin has a good guide linked below, but the most important guide to follow is your vehicle's manual.
https://www.michelinman.com/auto/aut...o-rotate-tires
Old 04-13-2024, 05:53 AM   #65
Default 5 lug bolts/tire
Anti-seize, white lithium grease, or red tacky grease ....... what's best for the five lug bolts on each wheel when rotating the tires? Me-thinks it is anti-seize because the lug nuts and bolts do not move.
What gets used for grease on the lug bolts on my Subaru at a service business like Tilton Walmart or Belknap Subaru?
And, how tight to tighten them when using a 4-way universal lug wrench?
Old 04-13-2024, 07:30 AM   #66
The spare is used as a way of keeping the car up while moving the other tires around. The last movement frees the spare so it can go back to where it is stored on the car.
Old 04-13-2024, 11:38 AM   #67
Many cars have a mini spare or a full spare on a steel wheel that doesn't match the wheels on the car.
Personally, I just rotate them front to back every 10,000 miles or every other oil change.
HTML code is Off
This page was generated in 0.51821 seconds
