Old 06-20-2004, 04:44 PM   #1
tna223
Default i/o overheat prob
I have a 98 four winns bow rider with volvo 6 cylinder i/o. Yesterday it overheated real quickly with smoke out the exhaust. New to boating, something in the cooling system, what do you think it could be and how much??
thanks
tna223 is offline   Reply With Quote
Old 06-20-2004, 05:44 PM   #2
madrasahs
Question to be continued
Blue smoke = $$$$
White smoke/steam = $$$
madrasahs is offline   Reply With Quote
Old 06-20-2004, 10:24 PM   #3
meredith necker
meredith necker's Avatar
Default overheating
I hope you shut it down immediately. Is it a new boat or used? Most marine engines are water cooled, impellers are rubber and wear out. Replacing an impeller is pretty routine maintenance. Anything that is Marine is expensive however. Good luck.
meredith necker is offline   Reply With Quote
Old 06-25-2004, 10:35 AM   #4
Bear Guy
Bear Guy's Avatar
Default mfg recall?
This is the third Volvo (boat) engine that I have heard of overheating. I would check to see if there is a manufacturer's recall or repair bulletin on the engine. Regardless, get it fixed - one of the overheating incidents I am aware of caused a fire in the engine compartment, forcing the crew to don life jackets and abandon ship!
Another volvo overheating discussion.
Bear Guy is offline   Reply With Quote
Old 06-25-2004, 12:13 PM   #5
ghoti
ghoti's Avatar
Try checking the water intakes on the outdrive. Blockage there could cause this. Costs you nothing!
ghoti is offline   Reply With Quote
Old 06-25-2004, 01:31 PM   #6
Old Chris Craft
I've never owned a Volvo I/O but had two similar problems with OMC drives. One had a bad water pump impeller and the other had a blockage of the water jacket in one exhaust manifold.
Old Chris Craft is offline   Reply With Quote
Old 06-25-2004, 03:14 PM   #7
scott hughes
Question over heating
you need to replace the water pump impeller.it is a common problem with those engines
scott hughes is offline   Reply With Quote
Old 06-25-2004, 06:44 PM   #8
Cal
Cal's Avatar
What Scott said. That is the most common cause and one of the cheaper ones to repair.
This page was generated in 0.09102 seconds
