Old 09-09-2020, 04:24 PM   #1
Default Island fireplace/chimney repair/mason?
We have a brick fireplace with a steel liner that is rusted out, the damper is shot, and a lot of bricks are loose at the hearth (yeah, a real gem!). Looking to have it looked at, made operational again and refaced in stone with a new hearth and mantle.
Any suggestions?
We did talk to Fire N' Stone, they lost our number the first time I called in July and now can't look at it for another month, with potential work being next season should we accept. Not thrilled so far.
Old 09-10-2020, 10:39 AM   #2
Hillcountry
Hillcountry's Avatar
Any suggestions?
We stopped at Fire n Stone a couple weeks ago lookin at propane stoves and they clearly seemed like they were going through some sort of down phase. No new product on display nor sale. I have had repair work done by them a few years back...not so sure they are in a good way there.
Old 09-10-2020, 01:21 PM   #3
Default Heatalator?
We had a Heatilator Fireplace when we first built. Basically a metal firebox with air chambers incorporated behind the fire box. Fans circulate air through the chambers and into the room. Great product, but it rusted out. A contractor doing other work offered to fix it by removing and bricking it up like a real fireplace. We didn't know, or ask, but Heatilator made a replacement kit for just this situation. Big mistake on our part.
Now, to do it again, I'd go for a fireplace insert and new stainless steel stovepipe so you don't have to re-line the chimney. Chances are, if your chimney has ceramic tile, it may not be in good condition, collecting lots of creosote.
Old 09-10-2020, 02:30 PM   #4
Ours may be a similar setup. It has a steel liner and there are vents on each side of the fireplace I haven't found a fan though.
Old 09-10-2020, 07:51 PM   #5
TheProfessor
Look up the name Huston.
There are two generations doing masonry work in the Lakes Region.
Don't think that they advertise - as word of mouth keeps them occupied with jobs.
Old 09-10-2020, 10:04 PM   #6
winni83
Ditto on the Huston brothers for masonry and fireplace work. Bob Huston did the stonework for our entry way and the rock gas fireplace surround with bluestone mantel and hearth. A true craftsman.
Old 09-11-2020, 09:40 AM   #7
Default Stone Mountain Masonry
You can't go wrong with Joe! The Bahre mansion is a good example.
https://www.stonemtnmasonry.com/contact
This page was generated in 0.08277 seconds
