Old 04-06-2004, 04:16 PM   #1
webmaster
Moderator
webmaster's Avatar
Default Forum Time Display
I received several emails and messages from users saying that their time display on the Forum was off by several hours. When I checked those user's settings I found that their time zone settings were off.
During the registration process you have an opportunity to set your correct time zone. If you didn't do it then you can do it through your User CP after logging in.
If the time display is not correct when you view the Forum please go into your User CP, change the time zone and save the settings.
Old 04-06-2004, 09:26 PM   #2
Merrymeeting
Merrymeeting's Avatar
Default Registration Process?
FYI only. When I first tried to register on the forum, I tried registering as your first notification indicated I would need to do. However, I received an error message that the user name I selected was already in use. So I tried my password and got in. Apparently I was already registered somehow and therefore was never prompted for much of the information.
Old 04-07-2004, 12:03 AM   #3
webmaster
Moderator
webmaster's Avatar
You must have already been registered for PhotoPost. PhotoPost and the Forum use the same login and once you are logged in to one you are logged in to both.
PhotoPost users should visit their User CP and set their preferences including the time zone.
This page was generated in 0.08248 seconds
