Old 03-17-2014, 12:36 PM   #1
Newcomers
Newcomers's Avatar
Default Propane Fireplace Service
We are new to the area and have a home with 3 propane fireplaces which don't seem to be operating properly. It does not appear to be a propane problem because we have had our propane company check them out. However, I would like to get a service in here to fully review the placement of the logs and the equipment. Can anyone recommend a good reliable service company? Thank you very much.
Newcomers is offline   Reply With Quote
Old 03-17-2014, 01:00 PM   #2
Default Builder Installed Products
I just had mine serviced by "Builders Installed Products". 1-800-626-7797
They have offices all over New England so I am pretty sure they will service whatever area you are in. The number I supplied is for their NH office which is in Auburn.
Good Luck!
Newcomers (03-31-2014)
Old 03-17-2014, 02:48 PM   #3
Meredith AK
Default Propane service
Rymes Propane and Oils has serviced our propane fireplace and propane wood stove. Tel #(603) 539-4194. Offices in Tilton and Osipee.
Meredith AK is offline   Reply With Quote
The Following User Says Thank You to Meredith AK For This Useful Post:
Newcomers (03-24-2014)
Old 03-17-2014, 04:26 PM   #4
Default Head's Electric in Laconia
sells and service propane appliances. Give them a call.
Old 03-17-2014, 07:10 PM   #5
We used Christian Repair last time we needed work done. He came out to the island and took care of everything needed at a very reasonable price.
Old 03-18-2014, 09:08 AM   #6
Pineedles
Pineedles's Avatar
Default Type of service needed?
What exactly needs to be done on a propane fireplace? I've replaced some of the "steel wool" in spots but other than vacuuming the outer areas what else needs service? I did notice that when igniting the fire this winter the flame makes a bit of a loud roar when starting, louder than I remember.
The Following User Says Thank You to Pineedles For This Useful Post:
Old 03-21-2014, 09:33 AM   #7
Newcomers
Newcomers's Avatar
We have different issues with each of the three propane fireplaces we have.
In the first case, the fireplace lights but emits a strong smell. Had propane company look at it- they re-positioned the logs but it still smells.
In the second it starts fine and then 5-10minutes later shuts off. Sometimes it re-starts itself and other times I have to turn off the switch and then re-start. It also puts soot on the front facing of the fireplace.
In the third case - the fireplace is completely enclosed in glass. When it starts- it gives such a pop- you think it may blow out the glass but then quickly returns to normal and no problem after that
I bet this is more than you wanted to know - but that is the case. We had energy savers here last fall - no luck //then the propane company- no luck
Thank you for reading all this!
Old 03-21-2014, 11:06 AM   #8
Happy Gourmand
Happy Gourmand's Avatar
1st and 2nd problems might be venting/draft issues. 3rd sounds like too much gas coming in before the igniter fires. Just a WAG
The Following User Says Thank You to Happy Gourmand For This Useful Post:
This page was generated in 0.19128 seconds
