Go Back   Winnipesaukee Forum > Winnipesaukee Forums > Area WebCAMs
Old 02-22-2007, 10:23 AM   #1
White Rook
White Rook's Avatar
Default Wolfboro Webcams
I used to enjoy seeing the Wolfboro webcams especially the one overlooking the public docks. They worked a couple of years ago, then stopped working, then began working only to stop again in Sept 2006. Does anyone know the reason why these webcams stopped working? Thanks.
White Rook
"Checkmate King II ... This Is White Rook .... Over"
White Rook is offline   Reply With Quote
Old 02-22-2007, 04:37 PM   #2
GWC...
GWC...'s Avatar
White Rook
Time and money, would be my guess.
Any volunteers to remedy the situation?
Old 02-22-2007, 05:37 PM   #3
mcdude's Avatar
White Rock:
WOLFECAM is back, once again. You'll need to download Java (if you haven't already) in order to view it.
...follow link for.. WOLFECAM
See this other thread for more new cams in Wolfeboro...
OTHER WOLFEBORO CAMS
Enjoy! McD
Old 02-22-2007, 07:25 PM   #4
Rose
Default Internet Exploiter
The Wolfecam apparently only works if you use Internet Exploiter.
Rose is offline   Reply With Quote
Old 02-23-2007, 12:02 AM   #5
GWC...
GWC...'s Avatar
The Alton Bay Webcam and the ClubCam work fine.
The WolfeCam and WashCam require an Active X to be installed.
No Thanks...
Try it for yourself (click the images at the left sidebar):
http://www.lakewebcams.com/
Old 02-23-2007, 12:16 AM   #6
GWC...
GWC...'s Avatar
White Rook
This might explain your frustration...
Old website Cam (Wolfeboroonline dot com):
http://wolfeboroonline.com/wolfecam/wolfecam.php
New website Cam (Wolfeboro dot net):
http://www.wolfeboro.net/webcam/north_main/nm_cam.jpeg
Time and money might have some influence on the subject, as well.
Old 02-23-2007, 09:09 AM   #7
Chris Craft
No Thanks...
Active X is fine as long as you select only for this site. It does not install any bad things on the confuser. The remote controls for my customers houses all require it and I have never seen it cause a issue. You definitely only want to allow certain web sites that you trust to install it.
Chris Craft is offline   Reply With Quote
Old 02-23-2007, 01:10 PM   #8
White Rook
White Rook's Avatar
Thanks to those that replied. I'm using Firefox as my browser and will consider using IE when necessary.
Old 02-23-2007, 09:36 PM   #9
GWC...
GWC...'s Avatar
Always remember that there is a big if in the middle of life, as in, I will not drown; if I am able to tread water until help arrives.
For those who desire to happily enjoy an Active X lifestyle while enjoying life sans IE, here’s some Active X info…
http://wiki.suselinuxsupport.de/wikka.php?wakka=ActiveX
Some additional, interesting reading…
http://searchsecurity.techtarget.com...902702,00.html
http://searchsecurity.techtarget.com...895952,00.html
For those who think Active X is a new concern, here’s some Old news for your viewing enlightenment...
http://www.pantos.org/atw/35547.html
Old 02-24-2007, 09:59 AM   #10
Phantom
Phantom's Avatar
I totally agree with Chris Craft above -- do not fear ActiveX or installing Java on your machine -- I have had it (various versions) through the years on a number of machines and it has never presented a problem ----- I can't say the same for some other downloads that I have inadvertently allowed ..........
This page was generated in 0.19357 seconds
