Old 07-02-2021, 09:48 AM   #1
Default Oil Filter ?
I want to change my boat engine oil (10Wx40), and install a new oil filter,
my problem is I don't know what type oil filter is on engine ?
The engine is a 2001 MerCruiser 4.3L V6.
What type filter should be used ? I don't want to remove current filter, until I'm ready to perform the oil change.
Can I use a automotive type filter, or does it require a marine spec. unit ?
Thanks !
Old 07-02-2021, 10:41 AM   #2
Ms Molly McKever
Default oil filter
Thanks !
2005 mercruiser 4.3 V6 mercruiser oil filter #35-866340k01
fuel filter #35802893t
quick silver oil filter #35866340q03
fuel filter #35802893q01
my oil is 25w/40 mercury quick silver
Ms Molly McKever is offline   Reply With Quote
Old 07-02-2021, 10:50 AM   #3
DPatnaude
There are many different 4.3L engines and oil filters. Even remote vs on the block makes a difference.
Suggest you find your engine here, https://www.mercruiserparts.com/v-6-sterndrive-engines and dig down to the block or remote oil filter schematics to find your correct part number.
You can cross reference to other filters once you know the right part number, but the OEM version is only in the $9 range.
DPatnaude is online now   Reply With Quote
Old 07-03-2021, 10:38 AM   #4
chillininnh
If the filter is in the back on the block it takes 883702K. If it's up front on a remote it takes 866340K01. Either takes the 802893T fuel filter.
chillininnh is offline   Reply With Quote
This page was generated in 0.15298 seconds
