Old 06-21-2018, 02:43 PM   #1
Default Tires - Mixing Tread designs ?
I have a couple tires on the front of my SUV that need replacing.
Rather than go to my local favorite 'Town Fair Tire', I called a local junk yard who has the exact size tire I need 245x60x18. 18" tires are hard to find !
He has a matched set of tires with extremely low milage, the catch is the tread design is totally different than my original Michelin Latatude Touring tires.
Matched set are Goodyear CS TripleTread, with a very different tread design.
Question..... Would it be wise to replace with Goodyears' with the tread design diff, and if so would it cause any issues with the car as it's 4WD (2013 Explorer).
Oh... one last question, maybe someone can explain what each of those numbers on the tire indicates, it's always been a mystery to me....
245 x 65 x 18
I know the 18 means that its an 18" tire, but don't know what the other numbers mean ???
Thanks !
Old 06-21-2018, 02:55 PM   #2
Meredith AK
Default Tire size
I can't answer your mismatched tread question, but tire size numbers mean the following:
245 This number indicates that your tire has a width of 245 millimeters
60. This number means that your tire has an aspect ratio of 60%. In other words, your tire's sidewall height (from the edge of the rim to the tire's tread) is 60% of the width.
18 diameter of wheel rim in inches
Meredith AK is offline   Reply With Quote
Old 06-21-2018, 03:30 PM   #3
Poor Richard
Poor Richard's Avatar
If the 4WD system is "permanent" as in always engaged, I would avoid mismatched tread design.
If the 4WD system allows for switching to 2WD, I wouldn't worry.
Old 06-21-2018, 03:46 PM   #4
Thanks Poor Richard ! The 4WD is constant and cannot be changed to 2WD.
Will avoid the tread diff. and remember for the future !
Lesson learned !
Old 06-21-2018, 03:48 PM   #5
Rusty
Click on the link below and than click again when it says to click here.
http://lmgtfy.com/?q=mixing+tire+tread+design+on+car
The Following User Says Thank You to Rusty For This Useful Post:
upthesaukee (06-21-2018)
Old 06-21-2018, 05:45 PM   #6
As PR said, if it is constant 4WD you should have all the same tires.
Old 06-22-2018, 06:28 AM   #7
Default AWD vs 4WD
Constant 4X4 are usually called AWD. It is electronically controlled. Some AWD can even sense the difference in tread depth!
I had a set of WR 3Gs on my MB with about 40% tread left. One tire suffered a road hazard. I had road hazard warrantee on all tires. The Nokian dealer strongly recommend replacing all 4 tires under the warrantee instead of one, otherwise the AWD mechanism will act up.
I replaced the WR 3Gs with WR 4Gs at no additional cost. Great tires!
LIforrelaxin (06-22-2018)
Old 06-22-2018, 06:58 AM   #8
It all been said here.... but some notes on All wheel drive....
You must really look at the manufactures instructions, especially when under warranty. They will specify the max tread depth offset. From my knowledge, the tightest tread depth offset is with Subaru... When one tire goes you just need to replace them all... It sucks I know.... but you can and will screw up the drive train of an AWD car otherwise... and all AWD will specify that the tires have to be matching for tread pattern etc.....
Old 06-22-2018, 07:36 AM   #9
The Real BigGuy
I understand the reason for same diameter (tread depth effect diameter) on 4 & AW vehicles but what is the issue with tread pattern. Never been able to figure that one out.
Old 06-22-2018, 10:57 AM   #10
I think it all has to do with clearances--the same diameter tires keep the differentials/gearing moving equally. Given that tread can affect traction, which affects slippage, which affects clearances/symmetrical movement, there is a need to keep tread pattern the same.
Old 06-22-2018, 06:20 PM   #11
Exclamation Slipped Belts from Accident?
Originally Posted by bigdog View Post
I have a couple tires on the front of my SUV that need replacing. Rather than go to my local favorite 'Town Fair Tire', I called a local junk yard who has the exact size tire I need 245x60x18. 18" tires are hard to find ! He has a matched set of tires with extremely low milage, the catch is the tread design is totally different than my original Michelin Latatude Touring tires. Matched set are Goodyear CS TripleTread, with a very different tread design. Question..... Would it be wise to replace with Goodyears' with the tread design diff, and if so would it cause any issues with the car as it's 4WD (2013 Explorer). Oh... one last question, maybe someone can explain what each of those numbers on the tire indicates, it's always been a mystery to me....245 x 65 x 18 I know the 18 means that its an 18" tire, but don't know what the other numbers mean ???
Thanks !
When dealing with a junk yard or used car tire establishment, ensure that you can return the tires if you uncover something wrong.
New car "take-offs" are there for a reason. (Noise, ride, tracking, etc.)
Old 06-22-2018, 06:31 PM   #12
Rusty
The week and year the tire was made is important also.
As you can see in the below image the tire has 5107 on it..51st week 2007.
Newbiesaukee (06-23-2018)
Old 06-23-2018, 03:15 PM   #13
JEEPONLY
This all seems a bit unclear to me. You replaced all tires, warranty was in effect (for one tire?), and no additional cost.
I've been here, before, and am interested in your final cost to replace all four tires (mounting/balancing included?).
Old 06-23-2018, 03:40 PM   #14
jeffk
jeffk's Avatar
Constant 4X4 are usually called AWD. ...
I had a set of WR 3Gs on my MB with about 40% tread left. One tire suffered a road hazard. I had road hazard warrantee on all tires. The Nokian dealer strongly recommend replacing all 4 tires under the warrantee instead of one, otherwise the AWD mechanism will act up. ...
Very interesting, I hadn't thought about this. The next car I am thinking about is an AWD. In the past I hadn't bothered with road hazard warranties because I considered it unlikely to happen and the cost was that of a single tire, maybe two depending on wear. But if the risk is having to replace all 4 tires, that makes the warranty a better deal.
Old 06-24-2018, 07:11 AM   #15
Default Warrantee
To make it clear, One tire hit a sharp object in the road. There was visible damage on the tire that appears to be a large gash in the tread. The tire did not lose air, but close inspection shows the aramid fiber was damage.
I showed the dealer the tire, as I knew I had the comprehensive package for all 4 tires. This include road hazard coverage, free replacement first 6 months or 2/32 of tread. after this the warrantee is pro rated.
The tires were worn to about 40% tread left. Because the car was AWD, the dealer suggest that I cannot replace one tire as the new tread will effect the AWD. He decided to replace all 4 tires under the warrantee. (Later I found out that Nokian has a road hazard warrantee included with all new registered tires, on top of the VIP road hazard warrantee. Not sure which was used.)
2 was pro rated at 43% and 2 was pro rated at 29%. This was determine with a tread gauge. The discount was credited toward the purchase of the new tires. I paid for the installation, shop fees and tire disposal. So $137 was credited toward the new tires.
VIP includes with each tire:
Tire rotation
Flat repairs
Tire pressure checks
lifetime balancing
changeovers
All free for the life of the tire.
I'm sure to be competitive, all tire dealers have similar deals. I don't shop around for perks, just tire prices. After this experience I will.
Old 06-26-2018, 09:17 AM   #16
nhcatrider
Traction. You don't want tires that grip better on one end of the car compared to the other, too easy to loose control in an emergency situation. Same reason why tire dealers encourage you to buy 4 snow tires instead of two. If you just put snow tires on the front of a fwd car you will find it very easy to loose control of the back of the car.
Old 06-26-2018, 10:10 AM   #17
Biggd,
I have had very good success a couple times buying tires with 60% and up tread life left on Ebay and them shipped to my door, most times free. just plug in your size. Two i did had odd sizes and sure enough i found them on there.
Old 06-27-2018, 12:15 PM   #18
Potential handling issues aside, I dont think the drive system cares at all about different tread. What is important though is the actual rolling circumference. One wheel making less rotation than the others is not good for 4wd systems is why it is recommended to replace all if the tires have more than 10% wear or I've seen no more than 3/32 difference.
Old 06-28-2018, 02:54 PM   #19
Poor Richard
It's more of a general statement to keep all "like" tires on each corner of a 4WD or AWD vehicle. The reality is, many of the AWD systems can handle mismatched tires and some systems aren't bothered even by different sizes of tire front to back.
On the permanent 4WD systems, the limitation typically comes down to the transfer case.
Tread design is likely not a factor at all for the mechanical aspect of a given vehicle drive system however mismatched tread design can result in complaints from the vehicle's electronics if the vehicle senses the ever-so-slight differences in rolling resistance or perhaps differences in tire design as a result of speed rating.
For whatever it's worth, of all the AWD and 4WD vehicles I owned, the only time I've ever replaced all 4 tires due to a tire failure was with the permanent 4WD system in my (then) 2005 4Runner.
HTML code is Off
This page was generated in 0.36707 seconds
