Old 07-17-2021, 01:29 PM   #1
Default Welding & Metal Fabrication needed
The lower rear 'rocker panel' of my car are rusted out and need replacing.
That said, I'm looking for someone who can do metal fabrication to make new metal/aluminum panel pieces and weld them to car.
Any recommendations are appreciated !
Thanks......
bigdog is online now   Reply With Quote
Old 07-17-2021, 05:30 PM   #2
TheProfessor
There used to be a metal shop somewhere near the Laconia airport and Lowe's in Gilford as I recall. That was over 10 years ago. Not sure if place still there.
They did metal cutting and fabrication.
bigdog (07-17-2021)
Old 07-17-2021, 06:04 PM   #3
Loub52
Loub52's Avatar
Thanks......
Stephen’s Frame and Collision in Belmont. In 2020, had the driver side rocker panel replaced, in addition to some other rust repairs, along with new running boards. His work was excellent, on time and fairly priced.
Thanks,
Loub52
The Following User Says Thank You to Loub52 For This Useful Post:
bigdog (07-18-2021)
Old 07-19-2021, 07:37 AM   #4
TheProfessor
If this is just replacement automotive body panels - then any automotive body shop can purchase these panels pre-made.
Many automotive body panels are actually made in Taiwan.
Now if your vehicle is a 1935 Pierce Arrow - that may require a machine shop.
bigdog (07-19-2021)
Old 07-19-2021, 08:13 AM   #5
Onshore
Thanks......
The rocker panels are "rusting" meaning they are typical steel sheet metal and you want someone who can make aluminum panels and weld them to the remaining steel. Is it possible to weld aluminum to steel? If so, is it practical / wise?
Old 07-19-2021, 08:51 AM   #6
4 for Boating
Default East Coast
Had a trailer welded to add supports / additional cross bars underneath at East Coast Welding over by the airport. (Go to the back of the building to find the office) Fair price and what looks to me like very good quality work. Can't hurt to stop by and talk to them.
1979 Lakeshore Road, Gilford, NH 03249
4 for Boating is offline   Reply With Quote
Old 07-19-2021, 09:59 AM   #7
Excellent work and a fair price at East Coast Welding. The bad news is he is very busy and you may have to wait. I know he builds the aluminum frames for Watermark docks and just that is a significant amount of work.
I talked to Al, the owner, a couple of weeks ago about some work for me. Like everyone else in business, he is having trouble finding good help. But, it never hurts to ask.
Old 07-19-2021, 10:25 AM   #8
TheProfessor
As mentioned numerous times here.
If the vehicle had been oil undercoated. There would be no rust issue.
Old 07-19-2021, 11:29 AM   #9
Just had my “new to me truck” oil undercoating done. After two weeks it still smells. Guessing that goes away
Old 07-19-2021, 12:39 PM   #10
Onshore
I do appreciate the value of oil/undercoating but that is not to my point. The OP is suggesting welding new fabricated aluminum panels to steel. These are two very different metals. Is this really doable?
Old 07-19-2021, 12:49 PM   #11
Kingfisher
Alum panels can be fabricated….but not welded to the original steel panels. Riveted or other fasteners yes, but not welded.
Kingfisher is offline   Reply With Quote
Old 07-19-2021, 08:28 PM   #12
When mine was done I smelled that for at least two months….
Old 07-20-2021, 10:46 AM   #13
JEEPONLY
And, how long does it leak oil on to your garage floor?
My point, really, is that my driveway is macadam, and probably couldn't stand oil leaking onto it for 2-3 weeks.
The idea of doing oil undercoating has appealed to me for quite a while, but I don't see a non-messy/viable way around the negatives.
Is that what the play is- saving the bottom of your vehicle v. putting up with a bunch of filthy, slimey crap?
Just wondering!
Old 07-20-2021, 01:01 PM   #14
Just wondering!
If you're the mechanic working on the chassis of an oily beast it's not enjoyable but then again neither is a rusty beast.
Old 07-22-2021, 07:16 PM   #15
TheProfessor
Actually, the mechanics appreciated an oiled vehicle. As nuts and bolts will come off easier.
Yes. Those that think that the oil will not drip should not get this done. And just live with a rusty old car that will need multiple rusty items fixed or repaired.
Old 07-23-2021, 03:24 PM   #16
TheProfessor
Metal Fabrication.
Across street from Ricker's Salvage in Tamworth, NH.
https://goshange.com/#!/gallery/miscellaneous
Thread Tools
Display Modes
HTML code is Off
This page was generated in 0.40011 seconds
