Old 04-11-2023, 05:18 PM   #1
Default Water Turn on Question
Any feel that turning on the water for the season this Friday is a going to be a problem. I do not believe so but my wife is questioning it from a freezing standpoint
Old 04-11-2023, 05:47 PM   #2
Pine Island Guy
Pine Island Guy's Avatar
Default go for it!!
Looking at the extended two week forecast there aren't any temps that go below the high 30s... even if it did hit freezing overnight sometime, it wouldn't be enough to create a problem in your pipes... it would take an extended few hours well below 32 to actually freeze solid... and with the shorter nights, I can't believe that would happen before next fall...
Looking like 78 on Friday, might have to take my first dip in the water!! -PIG
Pine Island Guy is offline   Reply With Quote
The Following User Says Thank You to Pine Island Guy For This Useful Post:
barefootbay (04-13-2023)
Old 04-11-2023, 06:04 PM   #3
Your wife is wrong. However, I will leave it up to you how you tell her
Old 04-11-2023, 06:27 PM   #4
camp guy
camp guy's Avatar
Default Water turn on
Happy Wife - Happy Life !!
camp guy is online now   Reply With Quote
Old 04-11-2023, 07:46 PM   #5
steve-on-mark
steve-on-mark's Avatar
Our water is on til December....a lot colder then than it is now. Mine will be on Thursday, so I think you're good!
steve-on-mark is online now   Reply With Quote
Old 04-12-2023, 01:37 PM   #6
As mine is going on Friday night or Saturday Morning, I don't think it is a concern............ Temps are warm enough now....while we might still get some low mornings I don't think we will see many below the freezing point...
ApS (04-12-2023)
Old 04-12-2023, 02:56 PM   #7
Merrymeeting
Merrymeeting's Avatar
Prior to moving here full-time, we always turned on Patriots Day weekend. In 20 years, with exposed pipes and no insulation, it was never a problem. A few years I got nervous. But never had an issue.
Old 04-13-2023, 06:51 AM   #8
Broken Glass
Turned our water on yesterday. The Lake is 36.83 degrees..Good luck with that swim…..I will join you in July!!
Old 04-13-2023, 09:09 AM   #9
It’s not a swim, it’s a cold plunge. Joe Rogen says they are good for you
Old 04-17-2023, 07:07 PM   #10
Gilmanton Greenie
I’m a plumbing contractor and turned my outside water on this past weekend.
Gilmanton Greenie is offline   Reply With Quote
The Following User Says Thank You to Gilmanton Greenie For This Useful Post:
AC2717 (04-18-2023)
Old 04-18-2023, 07:24 AM   #11
sunset on the dock
While we're on the subject of seasonal plumbing....I was always able to drain the pipes in my 70 year old cottage by gravity. A couple of years ago the bathroom shower had rusted out to the point of needing to be totally replaced. The old shower had separate hot and cold faucets. The plumber would not replace them and insisted because of code that he had to put in a mixer valve for the hot and cold water ("so no one can be scalded"). OK, fine, despite the fact that for decades no one had been scalded from said shower. I learned the following season that gravity drainage of the shower was no longer possible, despite having left the mixer valve half way open. Water gushed forth from my mixer valve the first spring. This left me with 2 alternatives: remove the valve for the winter (a pain in the neck) or blow out the valve with forced air from my compressor. I have chosen the latter and no longer have problems. But I still miss my 70 y/o classic hot and cold water faucets.
sunset on the dock is offline   Reply With Quote
The Following User Says Thank You to sunset on the dock For This Useful Post:
ApS (04-18-2023)
Old 04-18-2023, 09:27 AM   #12
That’s how I do my bunk house plumbing. Attach a low pressure air supply to the pipes and turn handle until water stops spiting out
Old 04-18-2023, 10:59 AM   #13
Similar set up 60+ years old. Everybody loves the old (non-restrictive) shower head and the soft lake water. Always just gravity drained and left the valves open. Once, about 30 years ago, I had a winter split in the 24" vertical pipe that runs from the valves to the shower head. Taught my daughter how to solder in a patch and all OK again, but I never could figure out why we had a split in the first place in a drained vertical pipe.
ApS (04-18-2023)
Old 04-18-2023, 06:05 PM   #14
Question Faucet = Hose Bib...
I had a similar split in a vertical copper pipe. It led to an outside hose bib, but can't recall if I'd absent-mindedly closed the faucet.
Maybe it was a cold north wind, but I didn't want to scare up the necessary hardware. Instead, I took a yarn from a nearby mop, and pressed it into the "breech". Using a Channel-Lock pliers from the opposite side. I then crushed the broken edges together on the yarn.
Instead of "just getting by" for the next 24 hours, the "fix" lasted several years until a visiting plumber rejected my handiwork.
I've saved my work product in spite of his disrespecting my provisional--but long-lived--repair.
Old 04-19-2023, 10:06 AM   #15
Aps--love our ingenuity.
This page was generated in 0.30647 seconds
