Old 12-12-2021, 05:23 PM   #1
Default Water Pressure issue ?
This morning I noticed that the water pressure at the kitchen sink faucet seems very low for some reason? The bathroom sink faucet in the next room appears to be fine and very strong pressure.
I checked the pressure in my holding tank and it reads 40psi. exactly where it should be.
The low kitchen faucet pressure just started noticing today?
I had installed a brand new hose and sprayer head on the faucet a few weeks ago so that couldn't be the issue. I checked all hoses under the sink and they don't appear tangled or crimped. And 'yes', the valve shut-offs are fully in the 'on' position.
What could possibly be causing this low-pressure ?
Old 12-12-2021, 05:33 PM   #2
Lakegeezer
Default Things to check
Does the sprayer work OK? There might be grit clogging the screen of the faucet. If that's not it, dig deeper into the project that you just did. Perhaps a washer is crimped. Take it apart and put it back together. Let us know what you find.
-lg
Old 12-12-2021, 05:35 PM   #3
Default Residue
The could be residue caught up in the spout at the kitchen sink. Some spots have a fixture that can be unscrewed and the screen that's in the can be cleaned off. Cheapest and easiest check.
Old 12-12-2021, 06:48 PM   #4
My kitchen faucet has some sort of shuttle valve that operates when you use the separate sprayer.
I hear it make a knocking sound like a steel ball bearing in a metal chamber.
Occasionally it will knock and no water will come out of either of them.
In that case I simply shut off the faucet and all goes back to normal .
I reported this to the manufacturer and they sold (grrrrrr) me a part.
This issue was so critically important that the new part still sits on my workbench two years later.
Old 12-12-2021, 06:51 PM   #5
If you have a quarter turn valve on the supply line under the sink it may have been inadvertently turned.
Old 12-12-2021, 07:36 PM   #6
I did turn the water valves back and forth a bit, and the water and pressure seem to be coming out faster..... FYI, The valves are the type you can open and close with half turn.
Do you think this is a valve issue ? The house is only 17 yrs old.
Thoughts ?
Old 12-12-2021, 07:41 PM   #7
Question
Thoughts ?
False alarm, faucet back to original issue, low pressure,
Checked bath faucet next room and flowing fine.
Really has me confused ???
Old 12-12-2021, 08:09 PM   #8
Gremlins. We all have them
Old 12-12-2021, 09:16 PM   #9
What brand faucet is it?
The big names have an 800# help line.
I'd bet they have heard it all before and might have an answer for you.
Old 12-12-2021, 09:32 PM   #10
If it's only in this one faucet, it's almost definite that it's a small clog. Unscrew the head and spray it out in another sink.
This happened to us a year ago, and we found a small piece of crystal or something had made its way into a new faucet head.
Old 12-13-2021, 09:37 AM   #11
The new installed 'American Standard' hose and faucet head came as one piece.
Apparently, the company made changes to engineering of this assembly, and made it so the head cannot be unscrewed from the hose like the original was made.
I'm thinking it 'may not' be the hose itself, but maybe the connector piece which connects the replacement hose with the old hose under the sink which connects to the water supply. Going to call-back American Standard and explain all, to see what they think.
Will report back when all is working again.
Old 12-13-2021, 12:20 PM   #12
TheProfessor
There is cheap China junk. Better China junk.
Even domestic brands make about 3 grades - to meet price points.
American Standard, Delta, Kohler - all make different subsets. Some are imported junk while others are domestic top quality - and some in between.
Guess today. One has to do some homework. Check reviews. (some reviews can be faked today). But do read up.
Thought I did fine years ago when I purchased a Price Pfister kitchen faucet with a lifetime warranty. It did work fine all of the time but the chrome wore off. And the chrome is not covered by the lifetime warranty.
Old 12-13-2021, 04:31 PM   #13
root1
Buyer be ware:
Many (most?) manufacturers will produce an item at a lower cost (ie less quality) to meet cost requirements set by big retail vendors like Lowes, Home Depot, Walmart, etc.
In these cases, if it looks like a duck and quacks like a duck .... it isn't necessarily a duck! Today's consumer has to be very savvy to catch the retailer at these games!
As an example, an Ariens snow-blower of a given capacity sold at HD is definitely not the same machine as sold at your full-service independent retailer.
Old 12-13-2021, 05:38 PM   #14
Originally Posted by root1 View Post
Buyer be ware:
While I know that's a possibility, I think it's far more common (and economical) to have different lines rather than making completely different machines. For example, Ariens has the "Classic," "Deluxe," "Platinum," and "Pro" lines, among others, but the top couple tiers are only found at independent dealers.
I think it's also important to note that the same thing can happen in reverse. I found what FW Webb was selling at Lowe's for much less moolah.
Old 12-14-2021, 01:12 PM   #15
I just got off the phone with American Standard and explained my problem, and they said that most water pressure issues are related to the cartridge in the handle. Apparently, this get clogged with sediment over time, and slows the water pressure.
They are sending me a new cartridge to install.
Will circle back to report if this fixes the issue.
Old 12-15-2021, 09:06 PM   #16
MDoug
Default Clogged Faucet
We had the same problem, resolved with a new faucet. Probably will install a new house filter. We get our water from the lake pump.
Old 12-15-2021, 10:37 PM   #17
TheTimeTraveler
Personally, I wouldn't buy a new faucet if I couldn't unscrew the tip at the point where the water comes out.
I clean this at least once a year or whenever the pressure is reduced, and I always manage to find some minuscule grain of sand (I take water out of the lake).
Old 12-21-2021, 07:06 AM   #18
swnoel
40psi? I'm assuming you have a well... it's either 50/30 or 60/40 unless someone has customized it for you. Also if the expansion tank has developed a leak in the bladder you'd short cycle the pump creating a rapid drop of pressure. I'm guessing since you only had the problem in one location it's not the expansion tank. One other thing you can check is the aerator on the faucet to make sure nothing is in it.
DotRat (12-21-2021)
This page was generated in 0.11448 seconds
