09-07-2010, 10:39 AM | #1 |
Anyone fix Anderson Windows?
We bought a house here in Melvin a few months ago and one of our Andersen windows is leaking. Anyone know someone who services them in the lakes area?
Thanks in advance. |
09-07-2010, 10:51 AM | #2 |
You don't really "service" them just buy another. Most likely it can be replaced with the same or comporable (sp) replacement for fairly short money.
09-07-2010, 11:17 AM | #3 |
Conatct Anderson. They are legendary for their customer service and may very well just fix it/replace it for you. Failing that, if indeed you do need to replace it, I can recommend a top-notch tradesman that works in the lakes region.
09-07-2010, 12:22 PM | #4 |
Middleton Building Supply is an Andersen dealer. I would contact them about how to file a warranty repair.
44 Railroad Ave Meredith, NH 03253-5842 603 279-7911 5 Kings Hwy Middleton, NH 03887-6217 603 473-2314 |
09-07-2010, 12:43 PM | #5 | |
Dan |
09-07-2010, 01:04 PM | #6 | |
But write down that number (it will be close to what we all recognize as a serial number in length) and contact Anderson directly, if it is a warranty item they will send out a rep to look at it and they will typically have a contractor that they use for warranty repairs. But start with Anderson. If they will not be able to help you, look at this site https://www.truth.com/main/ This is the hardware manufacturer for almost every mechanical component installed in major brand window made since the early 80's. Not everything is a do it yourself, but some things are. One thing to note, the date stamp will be located as Dan says, within the thermal pane, the number I am talking about will be on the window frame or hardware. It is not supposed to be removed for any reason and states that. Anderson is usually mounted on the top jamb of double hung and top or side for casements, awnings should be on the side. It will not be on a sash or on the sill. Last edited by jmen24; 09-07-2010 at 02:06 PM. |
