Old 08-12-2009, 09:25 PM   #1
Default Can't open Oil Fill on JetSki need Help!!
Hi Guys,
Need your help!!
I have a 1998 Tigershark 640xl. The fill cap is under the front storage cover right behind the mirror. The is a little tab in the middle of it and the tab pulls out. Now I do not know what I am supposed to do
Do I try to turn it? tried very hard will not spin
Do I try pulling it out? Tried very hard will not pull out
Ok so what is the correct way to take this cap off and how do I do it if it is stuck?
Thank you much, need to know right away so the fam can enjoy the jetski for the rest of the weekend, Had it filled before we bought it, I know it opens.
Thanks!!!
Old 08-13-2009, 06:53 AM   #2
chipj29
chipj29's Avatar
I don't know the answer to your question, as I own a Sea Doo, which simply unscrews. However, Tigershark was made by Arctic Cat I believe. You might want to give HK Powersports in Tilton a call, I believe that they sell Arctic cat snowmobiles, and may have sold the Tigersharks back in the day.
Getting ready for winter!
Old 08-13-2009, 06:59 AM   #3
My hunch is to depress the tab, and unscrew the cap at the same time. Tab is like a safety to keep cap from vibrating open. (???)
Old 08-15-2009, 02:17 PM   #4
Winnipesaukee
Winnipesaukee's Avatar
Default Parts diagram
Below is an exploded parts dia of your oil tank assembly. It looks like the cap just screws off...
Sail fast, live slow!
Winnipesaukee is offline   Reply With Quote
The Following User Says Thank You to Winnipesaukee For This Useful Post:
AC2717 (08-15-2009)
Old 08-15-2009, 10:30 PM   #5
Default Thanks
Hi Winni,
Thank you, I foudn out from a neighbor that has one that is gets stucks or almost like vaccum sealed. Have to put a pair of plyers on the tadband gentley twist to break the seal - Let you know how it goes
This page was generated in 0.08900 seconds
