Old 06-03-2017, 10:49 AM   #1
TriDad
TriDad's Avatar
Default 92 Miata clutch
I have a 92 Miata that needs to have the clutch adjusted. I'm not familiar with the garages up here.
Where would you recommend taking it?
[edited] we are in Gilford
TriDad is offline   Reply With Quote
Old 06-03-2017, 11:35 AM   #2
jbolty
where are you located?
Old 06-03-2017, 11:52 AM   #3
TriDad
TriDad's Avatar
That would help... Gilford on Laconia line
Old 06-05-2017, 05:15 PM   #4
NH.Solar
NH.Solar's Avatar
Miatas have hydraulically engaged clutches and I don't know if they are are adjustable.
Is your Miata normally stored all winter? If that is the case you may just need to add some brake fluid to your clutch. Open the hood and just in front of the driver's position you will see two translucent reservoirs, the larger is for your brakes and the smaller one for your clutch. Be sure that both are between the low and full marks. I hope that is all it is!
Peter
NH Solar
Old 06-06-2017, 02:20 AM   #5
Bob M
Default Miata Seat Covers
TriDad,
Sent you a private message.
Bob M
Bob M is offline   Reply With Quote
Old 06-06-2017, 04:59 PM   #6
loony
loony's Avatar
I own a '95 Miata, and yes they have a hydraulically actuated clutch. The slave cylinder gets leaky and with a lack of fluid can prevent the clutch from fully disengaging. Easy replacement, cost $20-$30. The most difficult part is bleeding air out of the system.
If your clutch is slipping, than that a whole other story.
Old 06-07-2017, 02:30 PM   #7
TriDad
TriDad's Avatar
Default Harmon Motors
Good diagnosis. It was the slave cylinder. It needed to be replaced.
I brought it to Harmon Motors in Gilford. Great people. They diagnosed it immediately and did the quick repair for a very reasonable price.
HTML code is Off
This page was generated in 0.17497 seconds
