Old 08-30-2021, 11:17 AM   #1
GodSmile
GodSmile's Avatar
Default 25 Swim Noodle Hacks
This made me think of FLL.
https://www.familyhandyman.com/list/...zWuSbBjfe7P8oc
The Following 4 Users Say Thank You to GodSmile For This Useful Post:
Biggd (08-30-2021), DRH (09-05-2021), Phantom (08-30-2021), trfour (08-31-2021)
Old 08-30-2021, 01:13 PM   #2
Grant
Grant's Avatar
Love the rod holder and ladder guard ideas.
One thing I've always used them for is SCUBA tank holders for the car or truck.
Cut a long noodle into three equal sections. Bore, cut, or burn holes through each section at the top, middle, and bottom (a few inches from the end). Then take a length of nylon rope, tie a knot in one end the feed it through the top holes of all three sections, separating them by about 6-8 inches and keeping the pieces separated by that much with additional knots.
Tanks rest between noodle sections, and then they don't roll around!
OR you can just buy one pre-made. See photo.
Old 08-31-2021, 06:11 AM   #3
For the Navy, they have 42" x 2.5"-diameter noodles colored dark battleship gray for all sorts of Navy use onboard their ships. Hey ..... if it ain't a battleship gray foam noodle then it's not standard Navy issue.
Anchors away with a battleship gray foam noodle ....... so many uses onboard with the Navy.
Navy SEALs who don't swim so good will use one as a swim belt for extra flotation to keep them from sinking and keeping up with the other SEALs who are stronger swimmers. Just like those Navy SEALs who don't swim too good ..... a foam noodle swim belt could make all the difference! ....
If anyone actually finds a foam noodle in battleship dark gray designed for military use, it will be a real unusual find. And of course the Army must have one in Army drab green.
So many adults are poor swimmers, unable to swim 100-yards, but tie a foam noodle swim belt around the waist very tight and it turns you into a super swimmer for the side stroke and breast stroke.
trfour (08-31-2021)
Old 09-01-2022, 03:42 PM   #4
....... and ....... another fantastic use for the foam swim noodle ..... to cover the horns on an aggressive GOAT ..... https://twitter.com/todayyearsoldig/...732033/photo/3 ..... three photos ..... three goats
Could work on a steer as well?
This page was generated in 0.23078 seconds
