Old 08-07-2022, 07:17 PM   #1
Default RV Class 3 - Advice on purchase ?
Need some Forum advice...
Going to look at a 2007 Winnebago Chalet (24ft). V8, with 73k Miles.
Is this a lot of mileage for engine ? Transmission ?
RV appears to be in excellent cond.
Things to look review/check for this type of purchase ?
Old 08-07-2022, 07:30 PM   #2
Default Almost like a boat
Almost like buying a new boat...ask if you can take it to an RV dealer for an inspection.
If the answer is no, perhaps you may want to walk away from it. Having an inspection, even if it costs you a couple of hundred dollars, could be the best money you spend getting any used RV.
The Following 2 Users Say Thank You to upthesaukee For This Useful Post:
bigdog (08-07-2022), Slickcraft (08-07-2022)
Old 08-07-2022, 07:32 PM   #3
^ This. You might even do both RV and auto shops.
Old 08-08-2022, 06:50 AM   #4
Default RVs
There are many factors to consider, not just chassis and motor. Definitely have it checked out by a reputable dealer or repair shop. I trust Bill's RV on Rte 9 in Chichester. If Campers World won't do it because of age then Bill's is the way to go.
Old 08-08-2022, 08:49 AM   #5
jbolty
Looking at a used rv starts like any vehicle, how does it run, any oil leaks, has the routine maintenance been done.
That's not a lot of miles however being used some is a good thing. Vehicles do not benefit from sitting parked for a long time.
But, the real killer for an RV is if there is any evidence of a roof leak or any water penetration anywhere in the roof or skin. If there is any sort of roof repair look inside in that area for water damage. The second thing is if the water system works property with no leaks and indication of having frozen with water in the pipes.
HTML code is Off
This page was generated in 0.20047 seconds
