Old 01-03-2023, 08:17 PM   #1
Loub52
Loub52's Avatar
Default 12V air compressor for water toys?
Looking for 12V air compressor recommendations for use on the boat. Anyone have experience with the outdoor master shark? A nice feature is that it has its own 12A fuse to as a safety feature ahead of tripping a breaker on the boat.
https://www.amazon.com/OutdoorMaster...8&sr=8-33&th=1
Thanks,
Loub52
Old 01-03-2023, 08:49 PM   #2
When I researched a few years ago, there weren't (m)any 12v inflators that could achieve high-enough pressure to inflate our Big Mable and other tow tubes, so I went with these two: the first to do 90% and the second to get the high pressure. That system has worked out really well both in terms of flexibility and outcome.
Coleman QuickPump https://a.co/d/8R9IYtN
AIRHEAD Watersports AIRHEAD Double Action Hand Pump https://a.co/d/cZVUnyr
Loub52 (01-04-2023)
Old 01-04-2023, 06:30 AM   #3
Loub52
Loub52's Avatar
Great point on the overall pressure required. Sounds like a very reasonable approach (and far less expensive).
Thanks,
Loub52
Old 01-04-2023, 07:15 AM   #4
Godspeed!
Old 01-04-2023, 09:40 AM   #5
jbolty
ditto. I have a coleman like that, which is essentially a fan. It moves a lot of air fast but no pressure which makes it great for the first part as you mentioned. The little 12v tire inflators move a tiny amount of air and would take forever but can do up to 100psi so both is the answer.
Old 01-04-2023, 12:19 PM   #6
We use Airhead electric pumps. We have a 12v with battery clips as well as a 120v.
Old 01-04-2023, 04:10 PM   #7
NHskier
We use the same combination of pumps as Thinkxingu, and found they work well for a Big Mable tube.
NHskier
Old 01-04-2023, 08:30 PM   #8
Loub52
Loub52's Avatar
Thanks to everyone for your experienced advice. Really looking forward to the next boating season!
Thanks,
Loub52
Old 01-09-2023, 01:20 PM   #9
LakeTimes
Have this version more or less (different brand but essentially same exact pump). Works great for all our inflatables (tubes, tow sports, inflatable dog ramp etc.) but won't get to the right PSI for our paddle boards. Once it hits pumps max, we switch over to hand for the final 3-4 PSI and good to go.
https://www.westmarine.com/west-mari...-19941376.html
This page was generated in 0.08934 seconds
