Old 08-30-2021, 07:36 PM   #1
RUGMAN
Default jet ski storage
This year I have the opportunity to store my jet ski in my heated garage, do I need to winterize , as in the past i had a local marina winterize and store for a price.
Old 08-31-2021, 06:15 AM   #2
I store ours in a heated garage, Seadoo 155 not winterized.
Old 08-31-2021, 06:27 AM   #3
Did that for years...just used a battery tender
DotRat (08-31-2021)
Old 08-31-2021, 07:31 AM   #4
burgerunh
Personally I would run antifreeze through the cooling system but I am cautious.
The Following User Says Thank You to burgerunh For This Useful Post:
TKD (08-31-2021)
Old 08-31-2021, 09:11 AM   #5
Agree. Cheap insurance .................
SAB1 is online now   Reply With Quote
Old 09-01-2021, 06:12 AM   #6
RUGMAN
thanks for all the replies.
Old 10-10-2021, 09:23 AM   #7
RUGMAN
Default storage of jets
Adding stabill to fuel tank, should I use red or blue?
Old 10-10-2021, 10:25 AM   #8
jetskier
jetskier's Avatar
Post Consider Seafoam instead
Personally, I prefer Seafoam for winter storage of my PWCs.
I have a 2002 GTX 4-Tec with a 1,500 cc engine. This is a closed loop 4 stroke, only open loop cooling systems can/need to be flushed (such as my 1996 GTX).
To winterize my 2002 GTX 4-Tec, I do the following:
  • Add Seafoam to the gas...it is a good idea to have a full tank to prevent moisture accumulation.
  • Remove the battery and place it on a battery tender.
  • Inspect the PWC (hoses, engine, hull) note anything that might need to be replaced or repaired.
  • Clean the PWC thoroughly and wax, if necessary.
  • Put Armour All on the seats.
I do flush the cooling system of the 1996 GTX with propylene glycol.
Jetskier
Old 10-10-2021, 03:44 PM   #9
RUGMAN
Where do you buy
Seafoam, I am going to store jet ski in my heated garage
Old 10-10-2021, 04:27 PM   #10
Walmart or any auto parts store or Tractor Supply or Lowes or Home Depot...
Old 10-10-2021, 07:29 PM   #11
startron is another good option.
This page was generated in 0.21412 seconds
