05-14-2020, 06:41 AM | #1 |
Engine hour meter wiring
Hi. I have a friend with a 2004 Bryant 234 deck boat and Mercruiser Bravo I/O. He claims the engine hour meter runs with the key in the off position and battery switch on. Is this normal that the meter is wired directly to the battery clocking hours? I don't know if it's an after market meter or OEM. I checked my Cobalt and it doesn't run even when in accessory position.
05-14-2020, 11:49 AM | #2 |
No, that is not normal or correct. The meter is supposed to measure actual time the motor has been running.
BTW, the ECM of the boat could be polled with the correct diag software to get actual runtime of the engine.
[insert witty phrase here] |
bobkatfly (05-14-2020) |
05-14-2020, 12:48 PM | #3 |
This boat should have an ECM that will log the engine hours....
No hour meter should run on just the battery switch.... Older boats had the hour meters hooked up to the ignition switch and could run with switch turned to accessory.... although most marine ignition switches do not have an "accessory" position. Woodsy
The Following User Says Thank You to Woodsy For This Useful Post: | ||
05-14-2020, 01:53 PM | #5 | |
None of the ignition switches (stock or replacement) in my Donzi's have had an "accessory position".. they were all Off-Run-Start. No need for an "accessory position" in a boat... that is what the battery switch is for, and sometimes a "master" accessory switch on the dashboard. Woodsy
05-14-2020, 05:07 PM | #6 |
Accessory switch
Neither do Formulas. Accessories can only be run when the electrical shutoff is on. I always shut off the main power when boat is not in use. With the main power switch off, I can still run the bilge pump. Other accessories including the motor cannot be used.
Formula hour meters only run when the engine is running. I did have a Liberator. Hour meter runs whenever the ignition switch is on even if the motor is not running. Same as my old Wellcraft. Guess it depends on who did the wiring.
05-14-2020, 08:23 PM | #7 | |
05-14-2020, 08:52 PM | #8 |
One of my Sea Ray's has an accessory switch position and one doesn't.
This leads me to wonder what extra components are energized when it's not running but the switch is in the run position. |
05-15-2020, 06:17 AM | #9 |
I believe the fuel pump energizes to prime when in the run position as well as the helm instrumentation, starting circuit safeties like oil pressure switch, etc.
05-15-2020, 07:44 PM | #10 |
When we bought the new Eastern with a Yamaha outboard we had Dave install an hour meter. It is tied to the ignition so it monitors actual running hours. The Eastern has one of those boat fuel gauges, almost useless. As I have a good handle on average gallons per hour and keep a log book, every 30 hours or so I stop at the gas dock.
Oh and when the boat is docked, he battery switch is turned off. |
05-16-2020, 07:13 AM | #11 |
Smart guages
When I had a Merc Optimax on my 1st boat, I had smart gauges installed. Two features I liked was the fuel flow meter and the fuel used. The former helped find the right throttle and trim settings for better fuel economy, and the latter was far more accurate than the rock and roll tank gauge. Needed fuel injection for the Smart Gauges and I was disappointed when I got the new boat with a carbureted engine.
05-16-2020, 11:34 AM | #12 |
The tach in my Wellcraft went bad a few years back and I replaced with one with the hour meter built into it.
05-17-2020, 08:19 AM | #13 |
It seems obvious that someone miswired that hour meter when they installed it, or when a repair was made.
If you are not good with electronics yourself and need help, I highly recommend Nick of Northeast Marine Industries out of Meredith. I've seen him work on other boats, he knows what he's doing, does a great job. He'll come to you as I've seen him often working out of his truck at our marina. https://nwmarineindustries.com/
