Old 11-16-2021, 05:33 PM   #1
Default Fix for Fridge scratch ?
I have a fairly new stainless steel refrigerator with a scratch on the front at the top. Scratch is about 3" long, and deep enough it stands out.
Is there anyway I can fix this ?
Thanks !
Old 11-16-2021, 06:11 PM   #2
John Mercier
I would need to see a picture from several angles.
Other than that, it may require a new panel.
Old 11-16-2021, 06:12 PM   #3
TheProfessor
You purchase a new replacement part.
Or place/cover with some bulletin board.
Old 11-17-2021, 07:52 AM   #4
phoenix
phoenix's Avatar
HD has paint specifically for appliances at least for white. which i used and not prefect but better. i think its from rustolean. they have have stainless also
Old 11-17-2021, 10:24 AM   #5
John Mercier
Rustoleum has appliance paint. It is an epoxy, so very durable when applied correctly.
But it will only cover surface scratches and blemishes.
We would need to see the picture of the scratch from various angles to determine if it is only on the surface or has created an indentation.
Also, the entire surface should be redone if this method is used to ensure a color match.
This page was generated in 1.40267 seconds
