Old 10-25-2017, 10:38 AM   #1
kjhils
Default De-Icer Advice
Attached is a picture of our dock.
Any advice on the best configuration for de-icer(s)? Our property is on the east side of Alton Bay so primary water flow direction is right to left if you're looking at the picture. The water is between 2-4' at end of dock this time of year
Appreciate the group's help in advance
kjhils is offline   Reply With Quote
Old 10-25-2017, 12:08 PM   #2
I assume that the de-icer you have sits on the bottom, not the type that attaches to the dock. The deeper water at the end of the dock is better since the deeper you go the warmer the water will be.
I have used them in the past about 5 feet off the end of the dock and they will open up a pretty large area. However, in the spring when the icebergs begin to move around if the wind is blowing the wrong way it could take out your dock anyway. It is a chance you take but the de-icer won't help with that. Your pilings should go a long way toward protecting the dock from moving ice.
Old 10-26-2017, 05:52 AM   #3
kjhils
Default DeIcer Type
Actually we "inherited" two de-icers that attach to the dock and one that sits on the bottom. Current thought is to attach one on each side of the dock and mount so it is "pulling" deeper, warmer water towards the dock
Old 10-26-2017, 06:23 AM   #4
Cobalt
Default De-Icers
I am only familiar with the type of unit that sits on the lake bottom, and placed it in front of the dock to the right. I have a right to left movement of water, and the De-Icer will open more water in that direction. A second De-Icer is placed to the right of a second dock.
I control each unit individually, and allows me to adjust run times depending on conditions. This will aid in protecting your dock, and minimize opening the shoreline. I use a camera to monitor the docks, and remotely control the De-Icers.
I hope this helps.
Cobalt
Old 10-26-2017, 07:18 AM   #5
Two lines are used to support the ice-eater, and they always gets tweaked or re-adjusted for best position by shortening, lengthening, or moving one or both lines after initial set-up and trial run. So, just start out with best guess knowing it will get tweaked.
The $150 electric control box with both timer and temperature sensor is the way to go, as opposed to one with just a timer.
Old 10-28-2017, 07:13 AM   #6
jetlag100
Default de-icer
Can you put some sort of boon up to prevent the ice from crashing into the dock when it starts to flow at the end of the winter as well?
jetlag100 is offline   Reply With Quote
Old 10-28-2017, 07:59 PM   #7
DRH
DRH's Avatar
Sadly, there really isn't anything that can stop large sections of ice from damaging or destroying a dock when the wind gets them moving. Depending on the size of an ice mass, how thick it is, how solid it is, and how fast it is moving, it can weigh many tons and have tremendous crushing power.
DRH
Old 10-29-2017, 08:59 AM   #8
webmaster
Moderator
webmaster's Avatar
Island Girl's video from last winter shows what you are up against. Luckily these docks were protected by breakwaters:
Old 10-31-2017, 01:34 PM   #9
That is just a fabulous video. Really drives home how much that ice moves.
Old 11-01-2017, 03:25 PM   #10
Knowing how much this ice moves, and how much it can't be controlled in a strong wind... I often wonder what drives people towards permanent docks. While certainly I know there are cases where their really isn't a choice. Articulating docks in most cases will work just fine, and then you get the structure out of the way....
While ice eaters, and the such do a good job keeping the ice away will it is forming... the real damage generally happens as the ice breaks apart and moves...
In short the Tripods the OP has will be there best defense against damage... Postioning the ice eaters, is really a set up that they need to do some trail and error work to figure out the best position. As for controlling their usage via temp or timer that as well is a trial and error process.
Old 11-01-2017, 06:21 PM   #11
If you are not around and present to keep an eye on your dock, to increase the frequency of ice eater operation ....something like a two day cold snap can do damage to your dock.
For example, after four weeks from Dec 10-Jan 10 of trial and error you think you got the timer just right ...... when on January 11-12 ..... a cold snap brings much colder local temps...... say, with temps dropping into the deep freeze .... the ice eater is no longer running enough to adequately maintain the open water and the ice build up wins the race verses the ice eater propeller keeping the water liquid.....with the deep freeze building enough ice to expand your dock from the legs in the water ..... maybe damaging the dock.
A two or three day deep freeze can do damage without any wind related ice movement ..... just the deep freeze. One can hear the damage happening as the dock structure gets expanded and broken by the new ice .....arrgghh .... bless this here broken dock! ...... ouch! www.laceyirrigation.com in Moultonborough will do weekly dock checks in the cold winter months, plus there's probably others.
When liquid water freezes into ice, it expands by about ten percent, and ice is much sturdier, stronger, tougher, and more elastic, at 5-degrees, than at 30-degrees. At 5-degrees, the ice is much more difficult to chop up with an ice chopper, than at 30-degrees.
Old 11-02-2017, 01:02 PM   #12
That dock is small. One on the bottom right in front of it will do the job.
Old 11-02-2017, 01:39 PM   #13
tc_mike
Just a friendly reminder to be kind to your next door neighbors. Try hard not to create unsafe access to the lake ice for those that like to get out onto the ice. Our neighbor used a bubbler one year (performing dock repairs)... no (easy access) ice fishing for us that year.
tc_mike is offline   Reply With Quote
Old 11-03-2017, 05:20 AM   #14
Wink Rock-Solid...
A breakwater can definitely keep a dock stationary!
This page was generated in 0.25632 seconds
