Old 06-14-2023, 06:44 AM   #1
MeredithMan
MeredithMan's Avatar
Default Not a great thing to wake up to this morning...
...I heard a big noise in the middle of the night during the heavy rains, but assumed it was thunder...I guess not..
Old 06-14-2023, 06:58 AM   #2
Yikes! That's weird. I think I see nails but it must not have been attached very well.
Old 06-14-2023, 07:10 AM   #3
MeredithMan
I'm guessing that pine needles and other debris from the last 14 years blocked whatever drainage it was supposed to have and the water built up and it gave way.
The Following 2 Users Say Thank You to MeredithMan For This Useful Post:
Blue Thunder (06-15-2023), LIforrelaxin (06-14-2023)
Old 06-14-2023, 07:29 AM   #4
Inside a porch is more surprising but water is tough. It can get anywhere.
Old 06-14-2023, 07:33 AM   #5
John Mercier
I can't tell for sure...
But it looks like they used soffit material and nailed directly to purlins attached to the deck joist.
The deck joist are beginning to show some signs of rot.
They have better systems.
BroadHopper (06-14-2023)
Old 06-14-2023, 09:04 AM   #6
MeredithMan
Default yes...
Yes, that's exactly how it was done. I am concerned if the joists are showing rot. A few of the deck boards on top have become punky where they get hit with roof water run-off...at a minimum, those need to be replaced. Might be time to bite the bullet and replace the whole darn thing with Azek or other material that will out-live me.
coltgov101 (06-19-2023)
Old 06-14-2023, 09:10 AM   #7
Nothing's worse than discovering hidden rot. We went to replace our porch siding at camp only to discover the whole sill had rotted out and quadrupled the work and cost.
Sorry, friend, but good luck!
Old 06-14-2023, 09:27 AM   #8
Unfortunately the practicality of putting in esthetic features, is often not good. you have to have a way to get that debris out, or the result is as you have experienced..... Hopefully the frame of the deck is still solid.... a few punky boards on top are easy to replace... if you went the "roof" for the deck below, just incorporate a way to pressure wash the debris out occasionally....
BroadHopper (06-16-2023)
Old 06-14-2023, 10:56 AM   #9
MeredithMan
So I made the mistake of telling my brother who knows everything, (just ask him), and got the earful of, "...that's what you get for having a finished look that is nice to look at. My deck that's open underneath will never have that problem...blah, blah, blah... )
Old 06-14-2023, 11:03 AM   #10
Charlie T
As much as you don't want to hear it, your brother is probably correct. Unless you have a waterproof membrane under the deck above, water is going to collect on the ceiling below. Eventually that is going to rot and you can see the results today.
Old 06-14-2023, 11:06 AM   #11
John Mercier
''Nail Pop" occurs on both sides of a deck. The expansion/contracting of the wood wicking moisture and then drying out loosens the fastener and allows for a small amount of rot around it.
If the panels are still good... you can check the level of rot... clean it up... add joist tape and reinstall the panels, but with screws that are larger than the current fasteners. Most likely replace the purlins and wrap those with the tape before securing.
The top decking can be fixed by a mixture of either deck grates or just replacing a few boards that take the pounding from drip off the roof.
(obviously joist tape what you can under those also).
Time and Mother Nature will rip down any structure.
Old 06-14-2023, 12:48 PM   #12
Nothing wrong with the finished look, unfortunately most builders, and consumers don't think it all the way through..... It doesn't take much pitch to get the water to run off, unfortunately all the "stuff" following through the cracks of the deck above are a different story... It should be easy enough to create some access points, that would allow you to put a pressure washer nozzle through and remove the "Stuff" with some pressure once every couple of years...
MeredithMan (06-14-2023)
Old 06-14-2023, 08:51 PM   #13
John Mercier
I don't think a hose or pressure washer would work.
The attachment to the purlins limits the gap created for the run-off of water and debris.
If you look at a system, like the Trex RainEscape, it creates a large gutter that has an opening deep enough so that all the debris flows freely to the catch basins, and the catch basins are big so less chance of clogging.
Just rather expensive.
Old 06-15-2023, 04:31 AM   #14
Arrow Count Your Blessings...
It didn't fall during lunchtime...
MeredithMan (06-15-2023)
Old 06-15-2023, 07:07 AM   #15
MeredithMan
Default You are SO right...
You couldn't be more spot on! When my son is here every few weeks, he and his dog like to sit on that patio furniture below the deck and just look out at the lake. If it had happened when he and the dog were there, we'd have much bigger problems than cleaning up broken vinyl soffit and pine needle sludge.
Old 06-18-2023, 11:09 AM   #16
1helpfulhandyman
Default Soffit
Had they used vented soffit instead of solid you probably wouldn't have had this problem !
1helpfulhandyman is offline   Reply With Quote
The Following User Says Thank You to 1helpfulhandyman For This Useful Post:
MeredithMan (06-18-2023)
Old 06-18-2023, 07:07 PM   #17
John Mercier
It would leak onto the patio below... which was what they were most likely trying to avoid.
Prior to decking, you can use Trex RainEscape... after decking you can use Timbertech Dryspace.
Other than that... you have to realize wherever the ceiling is attached to the purlin... that is the gap you have for water and debris.
Overtime, the purlins will rot, and the nails/screws will release.
Old 06-24-2023, 04:13 PM   #18
MeredithMan
Default Now for the repairs...
OK, so the mess is all cleaned up and now it's time for the repairs. A contractor who was referred to me by a friend came by the other day. I asked for two estimates: one to do the "short-term fix" to get things back to where they were and one that is a long-term solution to replace all of the wood deck boards and rails with Azek or something similar. I also asked him to think about what could be done with the "short term fix" that could prevent this from happening again, (thinking of John's suggestion of the under-deck drainage/gutter system). That was clearly something he had no experience with.
He was a friendly guy, but I just had the gut feeling that this might be beyond his skill-set. So, appreciate any recommendations on high quality, (and yes, that may mean high cost), deck guys. I don't want any hacks and I don't want anyone who does it part-time when they're not working at the fire station.
Thanks.
Old 06-24-2023, 08:47 PM   #19
John Mercier
It depends on what you choose.
Are you going to resurface the deck, and is Azek the product of choice?
In a perfect world, the contractor would have undergone certification by the manufacturer, know how to use their design tools, and be able to give you what the finished product and price would be before you sign a contract.
Old 06-24-2023, 10:28 PM   #20
Thanks.
Listen to your gut. If it’s saying no then it’s a easy decision
Old 06-29-2023, 06:27 AM   #21
RTTOOL
Banned
you need to clean it out every few years...
RTTOOL is offline   Reply With Quote
Old 06-30-2023, 07:05 AM   #22
TheProfessor
The whole thing needs to be replaced.
Hopefully, none of the rot has encroached into the sill of the main house.
Any carpenter can build a deck. Not all carpenters can build a deck correctly.
Trex has an interesting design website. LINK
Paul Haskel of Gilford. Name of an excellent carpenter.
Old 06-30-2023, 10:51 AM   #23
John Mercier
Trex has a better one in the deck planner.
But if he wants Azek, he should use the Timbertech one to deal with any nuances of the product line.
It will be easier when they go to order as the item codes will match up with the product.
This page was generated in 0.25173 seconds
