Old 09-26-2022, 08:04 PM   #1
Sue Doe-Nym
Default Cleaning boats and jetskis
This information is probably on here somewhere, but I don’t see it. We are about to put the jet skis away for the season, and since we are old and tired…even a bit lazy, we would like something that would clean and even shine them up a bit. They aren’t new, but it would be great to have them look more respectable. TIA for any suggestions.
Sue Doe-Nym is online now   Reply With Quote
Old 09-26-2022, 08:20 PM   #2
On the plastics, we use SC-1 on the new(er) ski and Back to Black followed by SC-1 on the older.
On the vinyl, we use Aerospace 303.
On hull stains, we use Bar Keeper's Friend followed by SC-1.
The Following 2 Users Say Thank You to thinkxingu For This Useful Post:
Smith Point (10-02-2022), Sue Doe-Nym (09-26-2022)
Old 09-27-2022, 06:01 AM   #3
I just use regular liquid car wax on mine. I put it on every year before it goes in the lake. I use NuFinish and it is sold at Walmart.
Sometimes, in my enthusiasm, I get wax on the black trim. It is easy to take off with a toothbrush and a product called "Back to Black"
If you keep it in the water during the season a lot of the waterline stain will come off if you hit it right away with a pressure washer. If that doesn't work an acid based product like "Slimy Grimy" makes it easy.
Sue Doe-Nym (09-27-2022)
Old 09-27-2022, 09:28 AM   #4
Default Lake yellow
Is it the yellow brown water staining? If so, as Tilton noted, slimy grimy works. I use Acid magic from Aubachon Moultonborough. Spray on, rinse off in 5 minutes. I do protect the aluminum trailer as Slimy or acid magic will discolor it. I keep an old tarp on hand for it.
stingray (10-08-2022)
Old 09-27-2022, 08:17 PM   #5
Good advice above. Provided the finish is not oxidized a good wax or polish like NuFinish should be great. I often use a wipe on product like Chemical Guys Boat Hybrid Shine periodically after waxing. It’s a spray on wipe off product that also helps with sun UV. They also have a neat warterless car wash I use period to the hybrid shine if the boat is at the dock and not on trailer.
the Bar keepers friend mentioned above will take off staining but it is an abrasive and not very gel coat friendly.
Old 09-28-2022, 03:49 AM   #6
Good note on the Bar Keeper's Friend—we tried it on a couple spots before using it, and if not pressing hard the gel coat stays intact. Definitely want to be easy with it, though.
Old 09-28-2022, 05:11 PM   #7
Winilyme
Hmmm…let me get this right. You are old and tired…even a bit lazy”
Yet you ride jet skis and are even getting them ready for another season.
Sue - you aren’t old and tired; you are young of heart.
Old 09-29-2022, 08:15 PM   #8
Sue Doe-Nym
Thanks for all the suggestions. We used a boat cleaner which got rid of most of the oxidation….I forget the name of it….but we will use the waxing product tomorrow in hopes of having reasonably presentable jetskis. If that’s the case, I will be sure to post the names of the products. Trying to get one that would accomplish everything didn’t seem possible.
Old 09-30-2022, 01:37 AM   #9
Correct. A one shot do it all doesn’t exist. If you are able to get the oxidation off I have always used Starbrite Marine Polish on my boat. after 25 yrs it’s still in new condition. http://www.starbrite.com/item/premiu...lish-with-ptef
This page was generated in 0.08322 seconds
