Old 02-10-2017, 09:55 PM   #1
jeffk
jeffk's Avatar
Default Can you get there from here?
This may require a little local knowledge because I don't see any official trail to where I want to go.
I live near and have access to the Corridor 15 trail near to where it goes across Route 25B in Center Harbor. I would like to get down to Lake Winnipesaukee in Center Harbor. Are there any local access trails off of the main trails to do that? Everything I see on the map puts me onto the lake a ways out. The nearest would be going in at Salmon Meadow Cove. Then I would have to go out past Black Cat and then into Center Harbor. I know there is an access trail to the Red Hill Irving gas station but from there to the lake???
Thanks.
jeffk is online now   Reply With Quote
Old 02-11-2017, 12:30 AM   #2
WINNOCTURN
WINNOCTURN's Avatar
Thumbs up Corridor 15 to Lake at Center Harbor
Jeff,
When you take the access road the comes back to Dave Fullerton's RED HILL Automotive and the Red Hill Dairy there is a trail that crosses RT 25. You should she some signage across the road showing were to go to access the Lake. The Trail is used to get gas at Dave's Station.
The trail goes through some Private Property. We had to reroute it this Season as we had several Riders do some damage to the owners property.
If I come up with more information I will add it to this post.
Name:  Center Habor 15 to Lake.JPG
WINNOCTURN
The Following 2 Users Say Thank You to WINNOCTURN For This Useful Post:
jeffk (02-11-2017), trfour (02-13-2017)
Old 02-11-2017, 02:34 AM   #3
jeffk
jeffk's Avatar
Great! I will check it out and ask Dave if I have trouble finding the signs. Thanks.
The Following User Says Thank You to jeffk For This Useful Post:
WINNOCTURN (02-11-2017)
Old 02-11-2017, 03:07 PM   #4
WINNOCTURN
WINNOCTURN's Avatar
Thumbs up Wild Meadow Canoe
There is a MARKED TRAIL that runs between the 2 Wild Meadow Canoe Buildings.
I should be easy to locate.
WINNOOCTURN
The Following User Says Thank You to WINNOCTURN For This Useful Post:
jeffk (02-11-2017)
Old 02-11-2017, 05:53 PM   #5
jeffk
jeffk's Avatar
Default As you said
easy to see. Thanks again.
This page was generated in 0.28026 seconds
