Old 05-19-2021, 06:56 PM   #1
Cshipley
Default driveway quote
We need to have a driveway put in leading to our new home that is set fairly far from the road - anywhere from 500 - 1000 ft. I know I will need someone to come out for a site visit. I am simply looking for a rough estimate on that type of work just as a starting point.
Cshipley is offline   Reply With Quote
Old 05-19-2021, 07:06 PM   #2
Little Bear
I used W.F. Richards & Son out of Meredith for my very long (1600’) and steep driveway. They did it 17 years ago, and I’ve never had a problem with washout since. Their number is 603-279-4214.
The Following User Says Thank You to Little Bear For This Useful Post:
Top-Water (05-19-2021)
Old 05-19-2021, 07:43 PM   #3
Cshipley
Thank you for the reply. I realize 17 years was a long time ago but would you mind sharing the cost if you remember?
The Following User Says Thank You to Cshipley For This Useful Post:
Old 05-19-2021, 08:10 PM   #4
TheProfessor
A tad bid of variables.
Trees/stumps.
Rocks.
Crushed stone.
Gravel.
Culverts.
Width.
And a driveway permit.
Old 05-19-2021, 08:20 PM   #5
DesertDweller
I looked at a lot a few years back where the house location was going to be 700 to 800 feet back from the road. There was a decent dirt path for about half of it and the other half needed to have some trees and large rocks removed. I have a guy who did driveway work for us at our existing place come out and give me a ball park guesstimate. To clear out the things that needed to be cleared out and put down a good base with ledge pack on top was going to be in the $25,000+/- range. It was enough that it scared me away from buying the lot. Not sure what the driveway path would be in your case and what type of trees and rock that need to be cleared but that was the number I was quoted. You're talking about a lot of materials to do a 1000 foot driveway.
Old 05-19-2021, 10:04 PM   #6
TheTimeTraveler
Trees/stumps.
Rocks.
Crushed stone.
Gravel.
Culverts.
Width.
I'm actually surprised that one needs a permit for a driveway since an actual structure isn't being erected......
Personally I look at a driveway as extended landscaping.
Anyways, maybe each Town has different rules and regulations.
Old 05-20-2021, 04:27 AM   #7
jeffk
jeffk's Avatar
You could probably get a company to come in and do it on the cheap and in a few years you would notice the pavement is starting to wave and crack because the base soil work wasn't done right. Also you might have drainage and freezing on some parts of the driveway because the leveling and drainage was not done right. Fixing problems like these could be cost prohibitive.
To do it right, the company has to remove 8 - 12 inches of soil, put in proper type of soil/gravel and compact it, and put in a couple layers of asphalt. They also have to carefully plan the drainage and landscape to make it work.
You get, and possibly regret, what you pay, or don't pay, for.
I recently got an estimate for 600'+ of driveway, a couple of culverts, an large apron in front of a 3 car garage, another apron in front of an outbuilding, a 60' spur going to a second house entrance, and a 80' spur for trailer parking. The estimate was $60K+. I plan to get some necessary work done soon and the rest done in 5 years or so. Splitting it increased the cost a little bit.
Old 05-20-2021, 04:30 AM   #8
Little Bear
I believe it was around $80k, not including paving.
Old 05-20-2021, 04:40 AM   #9
TheProfessor
This town does require a driveway permit. All has to do with street drainage - water run off - rain and snow. Piping under driveway with specific type/size of pipes.
If this is a state maintained road. Another ball of wax in permits.
TheTimeTraveler (05-20-2021)
Old 05-20-2021, 05:49 AM   #10
webmaster
Moderator
webmaster's Avatar
I just had my gravel driveway (not at the lake) paved a few weeks ago. $4500 for 1114 square feet. That included all prep work and removal of the gravel and wood beams. It looks beautiful.
Old 05-20-2021, 06:49 AM   #11
Ours is being done next month by Porter. I am on the road and will check square footage when I get home, but it is approx 9800 square feet- $22000 Reclaimed and paved is $22K.
To have the cracks fixed and sealed it was close to 4K- there are a lot of cracks!
DotRat (05-22-2021)
Old 05-20-2021, 07:24 AM   #12
I just bought an 10 wheeler load of ledge pack, $550. At 8" thick it covered about 1000 sq ft.
Old 05-20-2021, 05:56 PM   #13
In Gilford I was having my driveway paved a few years ago. The first 20 feet in from the street was fine but the rest was going to be paved. I went to the DPW get a permit and they told me I didn't need one since the new paving was not abutting a town road.
Old 05-21-2021, 11:41 AM   #14
TheProfessor
Do you need a permit to pave your driveway in your town ?
This page was generated in 0.31806 seconds
