Old 03-08-2024, 12:34 PM   #1
dippasan
dippasan's Avatar
Default Jet Ski PWC ramps
Hello all,
We purchased a couple of 2004 Sea Doo's last year.
I'd love to hear if any of you have custom built your own wood ramps for your machines or used one of the many "kits" and or plans that are available to build your own ramps.
Old 03-08-2024, 12:45 PM   #2
Define ramps? For towing or storage at the dock or on a beach
Old 03-08-2024, 12:51 PM   #3
dippasan
dippasan's Avatar
Ramps that would be on the shore and can be driven onto from the water and then the machines cranked/winched up.
Old 03-08-2024, 12:56 PM   #4
Such things are available through many vendors. A one piece plastic is neat. Inexpensive would be to locate a double wide jet ski trailer and pull it in and out of the water as needed
Old 03-08-2024, 12:59 PM   #5
Old 03-08-2024, 01:04 PM   #6
dippasan
dippasan's Avatar
The trailer idea is interesting.
Old 03-08-2024, 01:08 PM   #7
dippasan
dippasan's Avatar
I've seen these, and may be an option. I'll need to take a closer look once I get on the island
Old 03-08-2024, 01:20 PM   #8
When I bought my first machine years ago from a neighbor, he included a ramp made out of 2 x 4's and covered with carpet. Had a winch. As the water level dropped it became more difficult to pull the machine back into the water. Also, water logged and heavy to remove for the winter. I'd go commercial in aluminum or fiberglass with rollers for the bed. The kids now just leave tghe machine in the water tied between docks and trailer spring/fall. Neighbors do the same.
dippasan (03-11-2024)
Old 03-08-2024, 04:32 PM   #9
We have 2 Hewitt Slide-n-Go units. We are pretty shallow so we have the extension kits on them. They work well.
Here is my ice picture for the day, but you can see ours up on shore.
Old 03-08-2024, 07:57 PM   #10
Good way to do it, just be careful you don't suck crud up into the impellor as you get shallow. I'm seriously thinking about going down to one pwc this spring. So I would have no need for that lift if whomever I sell the pwc to doesn't want it.
This page was generated in 0.25083 seconds
