04-03-2020, 10:30 AM | #1 |
Marine Grease?
I need to grease both my trailer hubs, and the grease fittings on my Outdrive, can I use the same type grease for both ?
04-03-2020, 10:39 AM | #2 | |
I like using Merc 2-4-C on boat stuff, but if I had to I would squirt in some good high temp wheel bearing grease. I use the premise that I would rather have the wrong oil, than no oil! Edit note- the 2-4-C can be used in your wheel bearings. |
04-03-2020, 10:50 AM | #3 | |
Here’s what I use in all my trailers.... https://www.lowes.com/pd/Lucas-Oil-P...rease/50353742 Dan
04-03-2020, 11:25 AM | #4 | |
Thanks Dan ! |
04-03-2020, 11:28 AM | #5 |
Anything that goes under water needs marine grease. But if you're buying a tube of marine grease you might as well use it everywhere on a boat, even above the water line.
04-03-2020, 11:51 AM | #6 |
Yes it can...
04-03-2020, 01:56 PM | #7 |
For the outdrive it is always best to refer to your manual. 2-4-C as mentioned is very good. I have a Volvo Penta with an exterior fitting that goes right into the gimbal bearing. Very nice feature.
