07-23-2019, 10:04 AM | #1 |
Drained internal tank the easy way
I have a 1973 Sea Ray and had someone replace the controls on it and they were supposed to winterize it, they did not. I needed to drain the internal fuel tanks, 10 gallons each. I bought a 3/8 primer bulb and removed the fuel line from the fuel tank switch. I attached the bulb and then attached clear plastic fish tank tubing to the other end and fed it out the drain plug hole in to a gas can. A couple pumps of the bulb and out went all the bad fuel.
07-24-2019, 07:28 PM | #2 |
So now that you have all the old gas removed, what do you do with it? Getting rid of 15-20 gallons of old gasoline seems almost impossible to do?
Best way I can think of is to slowly use it up over something like six months time, by placing 1/2 gallon of old gas into your boat or car so's it gets mixed with maybe 10-20 gallons of good, fresh gas each use and slowly using it up. So, what's happening with all the old gasoline?
07-24-2019, 07:55 PM | #3 |
You can take old gas to NEDT’s household hazardous waste collection center in Sutton, MA. They will do pickups but I don’t know if they are limited to picking up in MA. There is a charge for the gas and the pickup.
