Old 07-20-2022, 12:06 PM   #1
XCR-700
XCR-700's Avatar
Default Lake temp
Anyone monitor Winnipesaukee water temp over time?
I feel like its warming up slower this year, or am I just impatient,,,
With the recent temps and sunny days and lack of rain, I expected the water temp to be a few degrees higher.
Anyone know where we stand on this?
GH
Old 07-20-2022, 12:27 PM   #2
Janet
Janet's Avatar
GH
I always thought the higher the humidity the warmer the lake temp. Is this a myth or am I correct in thinking this?
Old 07-20-2022, 12:45 PM   #3
GH
I literally said this to my wife last week...when I was struggling to get past my nipples!
Old 07-20-2022, 12:47 PM   #4
XCR-700
XCR-700's Avatar
I should remember this from college but that was too many years ago for me ;-)
There is a formula for heat exchange (air temp to water temp), but I think the bigger impact is just sunny day solar energy imparted on the surface of the water.
Maybe someone else can actually answer that???
Old 07-20-2022, 12:55 PM   #5
XCR-700
XCR-700's Avatar
Yup much below say 78 degrees F is a bit cool for me,,, But then our pool was 90 degrees on Sunday and that was way too hot! ;-)
Old 07-20-2022, 01:41 PM   #6
The Real BigGuy
I pulled the thermometer I keep at the end of my dock yesterday to see what water temp was. It hangs 6 ft down. It read 82! I dove in and yikes, no way. I think I need a new thermometer.
Old 07-20-2022, 02:02 PM   #7
XCR-700
XCR-700's Avatar
Im sure it wasn't 82! We should be so lucky.
Old 07-20-2022, 02:08 PM   #8
Micker
Someone posted this url from DES a good while back
https://www4.des.state.nh.us/rti_data/wein3_TABLE.HTML
Micker is offline   Reply With Quote
Old 07-20-2022, 02:30 PM   #9
Charlie T
Default Winni Home page
That same link is available on the home page of this Winni . com website.
Old 07-20-2022, 02:46 PM   #10
It's not myth, and humidity does factor in. As the dew point of air climbs out of the 50s (nice and dry!) into the low 60s (noticeably humid), and into the 70s (downright muggy - tropical), the rate of evaporation of water at the lake surface is retarded significantly. Turning a lb of water from liquid to steam (humidity in the air) takes about 1,000 BTU/lb. That heat comes mostly from the water itself and tends to chill the water. So you have two effects working against each other. A hot day's air and direct exposure to the sun's rays tend to warm up the surface water, while evaporation from the surface tends to cool it.
When you climb out of the water on a humid day, evaporation of water from your skin is a lot slower than on a dry day, so you don't feel the cooling as much as on the dry day. Similarly, after a prolonged hot, humid spell, which has warmed up the surface water considerably, a Canadian front bringing in dry air on the breeze enhances evaporation, and the surface water is cooled notably in short order.
While having nice warm water may be pleasant for hanging around in the water, we shouldn't want too much of that, as warm water temperature tends to work against water quality and general health of the lake.
The Following 2 Users Say Thank You to DickR For This Useful Post:
Descant (07-20-2022), Janet (07-21-2022)
Old 07-20-2022, 04:55 PM   #11
The link on this website showed 71 degrees at 11 AM and 75 at 4 PM.
That is a pretty big increase!
XCR-700 (07-20-2022)
Old 07-20-2022, 05:31 PM   #12
mofn
It has been slow to raise. We were saying the same thing up until last Friday.
Monday 7/4? w/ the clouds and wind in the afternoon chilled me to the bone, had to put a shirt on to warn up.
mofn is offline   Reply With Quote
Old 07-21-2022, 04:57 AM   #13
Mine read 80.
Old 07-21-2022, 06:06 AM   #14
For keeping warm suggest you look at the O'Neill Thermo fleece top designed for cold water swimming, best worn under a wet suit vest, down to about sixty degrees and colder with a full wet suit. This is NOT a wet suit. This is either a short sleeve or long sleeve, very tight fitting, black FLEECE top that gets very wet and good for wearing alone, or under a wet suit vest, a farmer john, or a full wet suit, or under a dry suit (have yet to actually do that).
Sold at Parafunalia in Gilford for about $60 ...... the short sleeve Thermo is the better for swimming ..... https://us.oneill.com/products/5022-2-thermo-x-l-s-crew because your arms are less restricted
Since late May, I've been swimming about 150-yards in 7-acre Corcoran's Pond in Waterville Valley which is about 5-10 degrees colder than Lake Winnipesaukee, especially after a rain fall. This tight fitting, black O'Neill Thermo top gets soaking wet but SOMEHOW, it really keeps in the heat in my chest area where it is most needed and works best under a wet suit vest for water 60+ degrees.
I also use a 28" x 2", $2.99 foam noodle swim belt tied tight around the waist because it is not too safe to be swimming in cold water that is over one's head, alone, and it works good for the side stroke and breast stroke and back stroke. It'll probably be good with the crawl, too.
Swimming Lake Winnipesaukee is more difficult due to the happening, big, wide open water movement from wind, waves and boat wakes.
Some drowning victims are over confident, strong swimmers ..... http://www.twitter.com/NH_StatePolic...77226272239618 ..... (click on photo to see WMUR video short) .....who think they will never have a problem out there. "Hell's bells ..... at age-92 I been swimm'n this here Squam Lake since the Hurricane of 1938 was here ..... which was over 40-years before Katherine Hepburn was here ..... -ayuh!"
What? ...... hoo-yah! .... who me? .... who me end up in the State Police twitter alerts as another drowning death...... no way! ..... not ME! .... not with my bright blue $2.99, 28x2" foam noodle, swim safe belt! ...... hoo-yuh! ....
Old 07-22-2022, 12:03 PM   #15
XCR-700
XCR-700's Avatar
Looks like we just hit 76 degrees yesterday, I think thats the highest this year!
Old 07-25-2022, 08:56 AM   #16
XCR-700
XCR-700's Avatar
As an aside,,, my pool broke its previous temp record of 92 degrees yesterday, the new record is now 95 degrees!
Overnight it dropped back to 89 degrees, which is almost cold by comparison,,,
This page was generated in 0.28274 seconds
