Old 08-04-2012, 11:09 PM   #1
Baja Guy
Default trade?
I have a perfect 19 pitch aluminum Michigan wheel 3 blade that uses the square hub. Is anyone interested in swapping a 21? The 19 is too short for my boat. The previous owner had that pitch so it's where I started.
Moderator if this is verboten I apologize & you can delete me.
1989 Baja Sunsport 196, Mercruiser 5.7, For Sale
1987 Formula 223 LS with 1997 350 Mag
Baja Guy is offline   Reply With Quote
Old 08-05-2012, 09:36 AM   #2
I have a 23P stainless you can try out. I am running a 19P now. I will have to look at the hub though- it is an 86 Alpha 1
Old 08-06-2012, 07:29 AM   #3
Default Prop Trade.
My boat originally came with a 19 pitch. The motor did not have a rev limiter so I swapped out for a 21 then 23 then 25. I settled for for a 24 pitch 4 blade. The 25 was 'blowing out' when turning or during hole shots. Now I want to try a 22' 4 blade. I traded in the 19 and 21. I have a 23, 24 and 25 available for sale or trade for a 22' 4 blade. All are SS Mirage.
The props will fit Alpha and Bravo drives. The Bravos requires a spacer which I have and comes with the prop. The 25 is a solid hub.
This page was generated in 0.23195 seconds
