Old 05-09-2013, 03:32 PM   #1
Chickie
Default Are Orioles Back?
Has anyone seen or heard an Oriole yet? They have nested in my backyard for over 20 years but didn't come back last year. Wonder if they have returned to the area.
Chickie is offline   Reply With Quote
Old 05-10-2013, 08:17 AM   #2
I had a lot around my house in Maynard all last two weeks, this week very few, they must be on their way North
Old 05-10-2013, 01:46 PM   #3
PaugusBayFireFighter
So funny you ask. I was just fishing on my dock and heard an unusual bird chirping. There was a male Oriole chirping away high up in a tree. Pretty bird.
Old 05-10-2013, 06:25 PM   #4
Belmont Resident
Belmont Resident's Avatar
Default Hmm
Just went to Hannafords and got me a package of them
Old 05-11-2013, 06:43 AM   #5
Bear Island South
Bear Island South's Avatar
My wife cuts an orange in half and puts them in the suet holder on the bird feeder...they love them.
Old 05-11-2013, 07:07 AM   #6
Rusty
Build one of these to hold the orange:
Here's What You'll Need
•One scrap 2 x 4, at least 13 inches long
• One 1-inch x 8-inch board, about 12 inches long
•One 1/4-inch dowel, at least 18 inches long
•Four 2-1/2-inch galvanized finishing nails
•Four common nails
•Waterproof carpenter's glue
•One screw eye for hanging the feeder
Recommended Tools
•Table saw
•Power drill
•Combination square
Easy as Orange Pie
1. Cut a scrap 2 x 4 at least 13 inches long.
2. Cut two 45° angles to form a centered peak on one end (this will become the top). Use a combination square or tri-square to help draw the cutting angles.
3. "Dog-ear" the corners at the bottom end of the 2 x 4 by sawing about 3/4 inch off each corner at a 45° angle.
4. Drill two 1/4-inch holes through the 2 x 4. Center one hole 1-1/4 inches from bottom of the board and the other 6-1/2 inches from bottom. Make sure you drill the holes perpendicular to the 2 x 4. This will ensure that your perches will be straight.
5. Cut two roof pieces from the 1-inch x 8-inch board. One section should measure approximately 6 inches x 7-1/4 inches and the other 5-1/4 inches x 7-1/4 inches. If you'd like, dog-ear the outside corners of the roof pieces by cutting off about 1 inch from each corner at a 45° angle.
6. Nail the roof pieces to the 2 x 4 peak with two common nails. The longer piece overlaps the shorter.
7. The oranges are held onto the feeder by spearing them onto 2-1/2-inch finishing nails. Center these nails on each side of the 2 x 4 about 3 inches above each perch hole. Drive the nails about 1 inch into the 2 x 4 at a downward angle so the oranges won't slide off.
8. Cut the 18-inch dowel in half for perches. Insert the dowels into the holes and center them. A little waterproof carpenter's glue in the holes will hold the perches firmly in place.
9. File or cut a flat spot in the center of the roof peak for a screw eye, which is used to hang the feeder. Drill a pilot hole first to prevent the wood from splitting.
10. A coat of deck stain is optional, but it'll help protect the wood from weather. Be sure the stain is dry before using the feeder.
11. Then cut two oranges in half, spear them onto the nails and wait for the orioles to show up while you sit back to enjoy a glass of iced tea.
http://www.birdsandblooms.com/Backya...-Oriole-Feeder
The Following 3 Users Say Thank You to Rusty For This Useful Post:
Bear Island South (05-11-2013), Lakesrider (05-13-2013), secondcurve (05-11-2013)
Old 05-13-2013, 07:09 AM   #7
smallies1
smallies1's Avatar
Back on little Winnisquam but not sounding very impressed with my orange Crush bottle and the foliage but he should know that.
smallies1 is offline   Reply With Quote
This page was generated in 0.28973 seconds
