Old 04-24-2021, 05:18 AM   #1
Little Bear
Default Problem with dug well
The dug well at a family property has been invaded by rodents. Plumber discovered several dead ones floating in the well, and suspects there may be more that have sunk to the bottom of the well. Looking for a company that will come fix this problem - drain, clean and sanitize the well, and do whatever else is necessary to bring the well back so the water can be used again.
Old 04-24-2021, 07:27 AM   #2
swnoel
My guess is this isn't the first time this has happened, just the first time you realized it.
Old 04-24-2021, 07:38 AM   #3
Little Bear
I can almost guarantee that you are correct. These types of wells are easily contaminated.
Old 04-24-2021, 11:03 AM   #4
MotorHead
Are you on Bear Island ?
Old 04-24-2021, 03:57 PM   #5
Little Bear
No. The well is on a mainland property.
Old 04-26-2021, 04:16 AM   #6
TheProfessor
For myself. I purchased a pump years ago. Sump pumb. with a hose.
For cleaning. Depends on what you mean for clean. Climbing in with a ladder and washing with detergent/bleach ?
Then you have to figure out how these critters are getting in.
If you can't do this yourself and don't have neighbors, friends, or relatives to do this. Then I guess - telephone a well company.
There are plenty of well companies around the Lakes Region.
Roth
Thomas
Daniels
and many more.
There used to be dedicated pump companies. Miller in Meredith was one. But sadly - he passed on.
Maybe someone else can chime in with suggestions.
Old 04-26-2021, 04:35 AM   #7
Question Suffocation?
The mice should have been able to move freely. Try inserting an 10-foot length of half-inch PVC pipe--capped so it floats.
Interesting occurrence.
Could an oxygen-free gas be introduced through natural inflow? Nitrogen from fertilizer? Maybe Carbon monoxide from a high-mounted generator? Carbon dioxide?
Not Radon...
Old 04-26-2021, 05:10 AM   #8
Little Bear
Roth
Thomas
Daniels
and many more.
Thanks for the suggestions l. By cleaning, I mean doing whatever is necessary to the well to make the water usable again. I personally would never use it for drinking, but it should still meet quality standards for showering and doing dishes.
Old 04-26-2021, 05:16 AM   #9
swnoel
Are you using concrete well tiles or is it an old stone well? Is this your primary well or a backup? How deep is it?
Old 04-26-2021, 05:39 AM   #10
Little Bear
It’s concrete tiles, and is probably 30’ deep, or thereabouts. It’s the primary water source for this seasonal property.
Old 04-26-2021, 06:19 AM   #11
swnoel
That's pretty deep for a dug well with tiles. Is the top capped with a concrete cap? There's no way any creature could get in properly capped with concrete. If it's not 30 foot you could get a ladder and a pump , pump it down, clean out the well and bleach it. I take it you have a shallow pump with foot valve. If you do and chose not to convert it to submersible ,I'd replace the foot valve while someone is down there. Is it possible to pump out the well with the pump already in the well? You could have a second person on top pulling up a 5 gallon bucket and muck it out until it was clean or use a second small pump.
Old 04-26-2021, 06:51 AM   #12
Little Bear
Maybe it’s not 30’ - I think that was a bad guess. It was dug in the 60’s, and I do remember people putting a ladder down the well and climbing in. It does have a concrete cap, but I’ll have to look at it to see if there are any gaps that might be big enough for these rodents to pass through. There’s also a hole above the waterline inside the well where a pipe passes through, so that will have to be checked as well. All I know is that I’m not climbing in that well, so will hopefully find a well company that can do this type of work.
Old 04-26-2021, 09:31 AM   #13
chocophile
chocophile's Avatar
Default Treatment System
You could consider a treatment system consisting of a series of particle filters and a UV sterilizer. A dug well will always have some level of microbial contamination, even after you address your immediate problem.
Lots of people do this, including us, with very good results.
Old 04-26-2021, 10:16 AM   #14
Very interesting reading about dug wells. I assumed most if not all were no longer in use. With today’s technology and resources why are these types of wells still in use? Not judging anyone, just ignorant of facts. Why not drill?
Old 04-26-2021, 11:08 AM   #15
TheProfessor
Cost. Money. Access.
A dug well is much less expensive then a drilled/artesian well with pump and tank.
One probably would not find a dug well on lakefront property. Just go inland a bit. But some older camps may have a dug well or use lake water.
Old 04-26-2021, 11:25 AM   #16
OP: what do you use for drinking water?
Old 04-26-2021, 11:27 AM   #17
Little Bear
Jugs of spring water.
Old 04-26-2021, 11:33 AM   #18
Little Bear
There are several dug wells still being used in the vicinity of ours. They were all put in during the late 50's / early 60's when the properties were being built. And they are lakefront (but not on Winni).
Old 04-26-2021, 11:45 AM   #19
Would it be worth putting a legit well in or working with lake water to solve all the problems, or is it cost/situation prohibitive?
Old 04-26-2021, 11:53 AM   #20
Until the late 80’s we carried in drinking water and pumped from the lake for all other needs. A well was drilled in 87 if I remember correctly. I would identify safe drinking and bathing water as a priority for any household.
Little Bear (04-26-2021)
Old 04-26-2021, 11:56 AM   #21
Photos of abandoned, old dug wells in nearby towns of Thornton and Sandwich ...... http://www.scenicnh.com/blog/2016/08...ned-dug-wells/ says they were usually 10-15' deep.
There is a roadside spring water discharge pipe on Route 3 in south Plymouth known as Crystal Springs Natural Water where there are many local residents who use it to fill water containers for home water use. I have tasted it and it tastes like the absolute finest, best, most clean and happy water anywhere in the entire world ..... http://www.foursquare.com/v/crystal-...96370407d7f194 ....... plus the price is my type of a price ..... totally free ..... and everyone is always extremely polite and well mannered, there.
So, eat your heart out all you artesian well, home owners with problem water ...... the #1 best water around is totally free ..... at the Crystal Spring on Route 3 in south Plymouth, NH.
Driving from Lake Winnipesaukee to Plymouth Walmart for a $19.88 pit crew, oil change; get off at Exit-24 in Ashland and take Route 3-north, and you will soon come to it on the left after crossing town line from Bridgewater to Plymouth at the huge Bridgewater, wood to electricity, Power Plant...... is usually a car or two or three parked there ..... all year 'round ...... getting watered. There must be a few hundred locals from nearby who prefer this Crystal Springs side-of-the-road water to what comes out of their kitchen faucet.
Old 04-26-2021, 12:06 PM   #22
Little Bear
Yes, yes and it's not my decision. I can only offer assistance to the family member who owns the property.
The Following User Says Thank You to Little Bear For This Useful Post:
thinkxingu (04-26-2021)
Old 04-26-2021, 12:26 PM   #23
TheProfessor
Maybe someone could throw out some $ numbers for the cost to put in a "legit" well ?
Old 04-26-2021, 01:07 PM   #24
chocophile
chocophile's Avatar
Default Drilled Well Costs
In 2019, we got two estimates for a drilled well. Neither company would provide a fixed-price quote. They quote $/foot drilled plus cost for trenching, well pump, pressure tank, fittings, etc. The variable is drill depth; if there isn't sufficient water flow, they keep drilling.
Both gave a range of $15K to $20K, based on the depth of other wells in the area.
Old 04-26-2021, 01:27 PM   #25
Sure many of you would disagree, but I would think clean water is more important then a boat or car
Old 04-27-2021, 05:04 AM   #26
The well drillers drill a hole into the ground maybe with a general idea how deep based on other wells in the area. How deep and how's the water quality is an unknown. Some drilled wells have a problem with small stone particles or bad taste or radon or arsenic.
Water treatment companies like www.culligancentralnh.com will install a treatment facility in your basement or heated garage for your well if you are not pleased with the initial faucet water after the well is first installed.
All things considered like the expense and unknown well drilling result cause people to stick with what they got for water, and go to the store for a five gal container of trusted quality water somewhat similar to the Route 3, road side Crystal Spring in south Plymouth ..... bring your plastic container(s).
Welcome to New Hampshire ...... water, water, everywhere ..... and not a drop to drink ..... or something like that! The www.mwra.com ..... is not in N.H. ...... live free or die ...... for your water ..... you is on your own water!
Old 05-12-2021, 04:26 AM   #27
Lightbulb Clean Water Isn't Easy...Recalls...
I remember recalls of bottled water going back 20 years. That first recall involved stores around Ossipee and western Maine.
Insert "bottled water recalls" into Google, and you'll find instances everywhere. Even Florida's ample springs have produced a recall in vaunted Publix supermarkets--citing "harmless mold". I've seen it myself, and wondered:
https://www.waterworld.com/drinking-...r-from-shelves
Coca-Cola produces "Smartwater" at $2 per quart. Made alkaline for the tummy, I drink it with my prescription medications with evening meals.
Lake Winnipesaukee water is distilled in this household for drinking. Our gallon home distillers put out a lot of heat for about six hours, so both distillers are on timers, scheduled to take off the morning's chill in the cottage--a double-win. Even after 20 years, our antique Japanese-made distillers are still $75 at Walmart.
That "critter" problem is discussed elsewhere on the Internet. Solutions, such as screens and shields are as close as Home Depot.
Thread Tools
Display Modes
This page was generated in 0.57030 seconds
