Old 08-05-2020, 08:17 AM   #1
milesbob
Default Acura MDX Timing Belt Change
My 2014 Acura MDX light came on saying I need a timing belt and water pump changed as I am now over 100k miles.
Dealer says to do those plus serpentine belt and hydraulic thing and coolant will run $1,300.
Anybody know of a shop up in Meredith/Moultonboro area or even south that is knowledgeable, and can do this without worrying it was done correctly.
thanks
milesbob is offline   Reply With Quote
Old 08-05-2020, 09:01 AM   #2
www.autohausmeredith.com is where I would take it to see what they say.
So, my 2013 Scion xB, 5-speed manual, with 205,000 miles still has the original four spark plugs, original continuous belt, orig fuel pump ...... all that's new are tires, brakes-140k, various light bulbs, wiper blades, oil/filter, anti-freeze, and engine air filter and had the front windshield replaced once ...... so, how does that work ..... what's up with this. Plan to keep driving it until it needs some unknown super expensive repair or something????
And, when that happens, I will call Busky's Auto Repair in Ashland to come haul it in for repair on their flat bed truck ....... that's my plan. Busky's in Ashland, Rt 93-Exit 24, is a wicked good repair place for a car like mine!
Old 08-05-2020, 09:38 AM   #3
steve-on-mark
steve-on-mark's Avatar
thanks
Dover Honda...1165.00
steve-on-mark is online now   Reply With Quote
Old 08-05-2020, 04:40 PM   #4
TheTimeTraveler
So, my 2013 Scion xB, 5-speed manual, with 205,000 miles still has the original four spark plugs, original continuous belt, orig fuel pump ...... all that's new are tires, various light bulbs, wiper blades, oil/filter, anti-freeze, and engine air filter and had the front windshield replaced once ...... so, how does that work ..... what's up with this. Plan to keep driving it until it needs some unknown super expensive repair or something????
The original poster was posting that his timing belt light came on at over 100,000 miles.
I could be wrong, but I believe your Scion has a timing chain instead of a timing belt. A timing chain should last a lifetime without any issues, while timing belts do need to be changed around the 100K mark.
Shame on Automobile Companies to continue producing vehicles with timing belts instead of timing chains.... A real easy change on the production line!
Old 08-05-2020, 04:48 PM   #5
I remember years ago I owned something that had to change the belt every 30k. Last few cars I always investigate belt or chain. Never belt
Old 08-05-2020, 06:07 PM   #6
songkrai
Many newer vehicles have an engine with a timing chain. With a timing chain - usually needs no maintenance and will last virtually forever.
Engines with timing belts. The timing belt is a piece of rubber/plastic - usually.
The timing belt should be changed as per owners manual.
There are two types of timing belt engines.
Interference and Non-interference.
If you have an interference engine and the timing belt breaks - the engine is toast. Gone. Destroyed.
If you have a non-interference engine and the timing belt breaks - the engine just stops. No damage to engine.
When purchasing a new or used car. It is best to check what kind of engine that car comes with. Can save quite a bit of money down the road.
Old 08-05-2020, 06:37 PM   #7
jeffk
jeffk's Avatar
You might give Burn's Automotive in Moultonborough a call.
Old 08-06-2020, 09:27 AM   #8
Most 4cyl cars have gone back to chains but many V6 engines still have belts.
As warrantee's get longer the manufacturers will go back to chains as the don't want to be paying for belt replacements under warrantee.
It was all a ploy to get people to return for service and a big repair bill.
We did many timing belt replacements at my shop over the years. The earlier ones had very thin belts that wouldn't last 100K but the newer belts are much thicker and will last beyond the manufacturers recommended time change. The belt runs the water pump, that usually goes first and takes out the belt.
Belts are rubber and the biggest contributor to belt deterioration is time.
Over time they dry out and crack.
HTML code is Off
This page was generated in 0.31120 seconds
