Go Back   Winnipesaukee Forum > Winnipesaukee Forums > Marketplace
Old 08-24-2022, 10:49 AM   #1
Cal Coon
Default Looking for a used outboard motor
I'm looking for a used two stroke outboard motor for a 17' boat. I am looking specifically for a 20" shaft between 115 and 140hp, no older than late eighties. My preference is Yamaha, Johnson/Evinrude, but will consider other's. Prefer it to come with controls, but not a deal breaker, and it's ok if the oil injection has been disabled. I actually prefer to premix. I'm not looking for any project motor's, I'm looking for something that is in real nice shape, but may be in need of typical maintenance, ie: water pump/impeller, thermostats, lower unit gear oil, etc, etc. That is all stuff I will do to whatever motor I end up buying anyways. It must be able to be demonstrated, (on a stand is ok), and I will perform my own compression test. If anyone knows of something around these guidelines, send me a phone number in a PM and I will make the call, or I can PM you my phone number if you prefer. Thanks for any help in advance.
Old 08-25-2022, 07:21 AM   #2
Default 2 strokes
Fay's Boatyard caters to the sailing community. They may just be what you are looking for! You can also try Dave's Motorboat Shoppe.
HTML code is Off
This page was generated in 0.08756 seconds
