Old 11-06-2011, 07:54 AM   #1
pkadventures
Default Noisy Generator!
The good news is that the generator works wonderfully! The bad news is that it is SO loud!! We find it difficult to sleep in the house when it is running and we feel badly about what our neighbors must be hearing.
Any suggestions? We are thinking about building something around the generator with access doors and vents. Thanks!
pkadventures is offline   Reply With Quote
Old 11-06-2011, 08:57 AM   #2
There is one thing you can do that will make a big difference and that is to extend your exhaust and pipe it into a 5 gallon or larger bucket of water. It will make all the difference in the world and won't hurt the performance of the generator.
DO NOT attempt to build a cover for your generator. Most likely your generator is air cooled and needs all the air it can get to stay cool. Any attempt at all to cover it, even if you add vents will not allow it to cool properly and you will burn it up.
welchislandman (11-07-2011)
Old 11-06-2011, 09:08 AM   #3
Extending the exhaust as already suggested, may help. I've done it with mine but I'm not sure yet if it's done more than move the carbon monoxide further from the house. I've heard of the water bucket trick but keep in mind that will add back-pressure to your unit which may, or may not, make a difference in performance. Variations on this include running the exhaust into a 'dry-well' filled with gravel or adding another small muffler at the end of the run.
I also put a piece of plywood about a foot from the genny as a noise-screen. I think this helps deflect a bit of the noise. It might be more effective if I added a piece of foam to the back of it.
Old 11-06-2011, 08:08 PM   #4
Winnisquamguy
Winnisquamguy's Avatar
We did the plywood trick all the time at different job sites. It was more of a defection I think, because it was just as loud on the other side. Might not work with the neighbors.
Old 11-06-2011, 09:26 PM   #5
AB_Monterey
AB_Monterey's Avatar
Replace that cheap little muffler that it came with.
The Following User Says Thank You to AB_Monterey For This Useful Post:
Rattlesnake Guy (11-07-2011)
Old 11-07-2011, 09:42 AM   #6
welchislandman
welchislandman's Avatar
With our 6000w gen I noticed my govenor was set to full throttle. with my load, I was able reduce the setback and ensured the voltage was not lower than 230v on the meter. Lowered the noise quite a bit since it wasnt running wide open. I also dont run my gen at night and restart it early am to get the heat/water back running.
welchislandman is offline   Reply With Quote
Old 11-07-2011, 01:34 PM   #7
RLW
RLW's Avatar
EEKS, looks to me as if that maybe running in a closed or partially closed area.
Old 11-07-2011, 02:14 PM   #8
TOAD
TOAD's Avatar
Diesel work every time.
"Government is not reason, it is not eloquence, it is force; like fire, a troublesome servant and a fearful master. Never for a moment should it be left to irresponsible action.....Unknown....but attributed to George Washington
TOAD is offline   Reply With Quote
Old 11-07-2011, 02:57 PM   #9
Default Its quiet when its off
With the temps we had in this outage there was no need to run the gen all night long.Get up a little early,start it up and the house is warm in an hour.
Old 11-07-2011, 06:11 PM   #10
chunt
Shouldn't change the governor setting. The motor has to run at multiples of 60 to maintain 60HZ power frequency. Small portable generators typically will run at 3600 rpm to maintain the 60hz power frequency.
chunt is offline   Reply With Quote
Old 11-07-2011, 06:46 PM   #11
RLW
RLW's Avatar
Smile
The above is true, however they are producing new generators that reduce the RPM as the load reduces. Knowing this, how does it perform as stated above?? That is just me asking the question as I do not know..
Old 11-07-2011, 07:28 PM   #12
brk-lnt
brk-lnt's Avatar
Some of those are inverter generators. They basically make a lower-voltage that is run through a circuit to great 120V/60Hz power. So, the motor speed does not directly effect the power cycle frequency of the power generated.
[insert witty phrase here]
Old 11-07-2011, 08:41 PM   #13
Wow...that is really taking a chance...hope you have a CO detector or two.
BT
Old 11-07-2011, 09:45 PM   #14
Another way to go a little quiter is spending good money and purchasing a Honda or equivalent. These units are tolerable but will set you back a few thousand dollars.
Old 11-07-2011, 10:29 PM   #15
AB_Monterey
Boys,
It wasn't running in that location.
Old 11-08-2011, 04:36 AM   #16
Belmont Resident
Belmont Resident's Avatar
Default Looks like a garage or shed
Lots of folks run them in a garage with the windows open to vent the fumes and reduce the noise.
Old 11-08-2011, 06:55 AM   #17
RLW
RLW's Avatar
Smile
That to is an extremely dangerous idea. You heard the story on the news last week where a family was over come from a generator exhaust that went into the home through a broken window in the basement. Yep, the generator was outside the house in wide open air space not a location with windows and doors open.
Old 11-08-2011, 07:05 AM   #18
Maybe they do but it is extremely foolish and dangerous to do so.
BT
Old 11-08-2011, 08:11 AM   #19
Rolie
Rolie's Avatar
Default Fumes
If the garage is attached to the house, they won't do that too many times..maybe even just once!
Rolie is offline   Reply With Quote
Old 11-08-2011, 08:39 AM   #20
AB_Monterey
That's a detached shed btw.
But with that car muffler on there (got it at the dump), that thing is QUIET.
Old 11-08-2011, 12:48 PM   #21
pkadventures
Default Clarification from OP
Interesting discussion and certainly safety trumps noise in our priorities!
To clarify our generator situation, it is full house disconnect located in the yard outside our house. We live in the house year round but part-time. In our research we found a company (Acoustiblok out of Florida - primarily industrial applications) that sells sound absorbing panels. They sent us a picture of a solid fence with their panels on the inside surrounding the four sides of a residential generator. Something we are considering.
Thanks for the suggestions, of all kinds!
Old 11-08-2011, 02:47 PM   #22
That have a nice pimped out chrome tip on it?
Old 11-08-2011, 03:05 PM   #23
I would have to assume that BR was talking about a detached garage and or shed. Never run one in an attached garage or garage under even with the doors open. If its really stormy out I have enough wire to reach my detached shed(75 ft) away. I just face the exhaust out the door and don't spend any time in there during or after for a few days.
Old 11-08-2011, 05:20 PM   #24
Belmont Resident
Default Yes siksukr I was.
I honestly did believe anyone would think otherwise, but I guess I was wrong.
I know of several people who have their transfer switch located inside their garage or run them inside the garage with extension cords going into the house. This allows the security of having the generator inside instead of outside where it can be stolen as many have been.
Old 11-08-2011, 07:03 PM   #25
MarkinNH
It is a very doable scenario IMO. All a person needs to do is to use some Common Sense. Proper exhaust, proper fresh air ventilation, regular maintenance and inspections to insure the above and did I mention common sense.
I know of several propane fired standby generators that are in enclosed buildings, these generators have been there for Years without any issues.
Unfortunately the most important key ingredient, Common Sense is severely lacking in todays society
MarkinNH is offline   Reply With Quote
The Following User Says Thank You to MarkinNH For This Useful Post:
Belmont Resident (11-09-2011)
Old 11-09-2011, 06:02 AM   #26
brk-lnt
brk-lnt's Avatar
Propane is way different than petroleum or diesel generators. Those can be safely run in occupied spaces with far less issues. That's why you see forklifts in warehouses running on propane, not diesel...
A gas/diesel genset in an enclosed space operated by a homeowner is a recipe for death, especially if that enclosed space has any ability to exchange air with a living space.
Old 11-09-2011, 07:22 AM   #27
MarkinNH
This is where the use of Common Sense needs to come into play.
Old 11-09-2011, 07:57 AM   #28
I always thought those things ran on butane. I'm pretty sure propane does produce carbon-monoxide. There are catalytic heaters that use propane that can be used indoors but motors can be hazardous.
Old 11-09-2011, 08:47 AM   #29
Common sense is not that common any more.....
Old 11-09-2011, 09:35 AM   #30
RLW
RLW's Avatar
Smile
I think we are on this subject, don't you???
Old 11-09-2011, 05:30 PM   #31
Belmont Resident
Default Another thought
You could always hook up an exhaust hose and vent it outside of the detatched holding area. Thats what they do in all automobile repair shops.
I do like the idea of the extended muffler because I'll bet the end never even gets warm so you could use just about any hose to vent the exhaust.
Winnisquamguy (11-11-2011)
This page was generated in 0.30181 seconds
