Old 06-16-2021, 08:38 AM   #1
Hivolt
Default Middle ground shoal rock danger?
Are there any rock obstacles (at current lake levels) through middle ground shoal? Or is that marked for the deeper drafting vessels? The bizer chart doesn’t appear to show any and marks the shallow at 4’ it looks like.
Hivolt is offline   Reply With Quote
Old 06-16-2021, 05:57 PM   #2
gwhite13
I would not bet my lower end on it. Simply go around.
gwhite13 is offline   Reply With Quote
Old 06-17-2021, 09:22 AM   #3
WJT2
Default Middle Ground Shoal
Clearly marked on my chart. Two Black tops and Two red tops and Flashing Marker #16. Go around! Stay east/north or west/south depending on your course.
WJT2 is offline   Reply With Quote
Old 06-17-2021, 09:48 AM   #4
Jdarby
Jdarby's Avatar
Saw a pontoon floating in there last Sunday.
Jdarby is offline   Reply With Quote
Old 06-17-2021, 10:15 AM   #5
Hivolt
I was interested for fishing purposes. I guess I’ll crawl around on a sunny calm day when I can see bottom. I knew some things are marked because the mount drafts 9’ for example the 2 black top bouys between Ames and Diamond Island.
Old 06-17-2021, 11:18 AM   #6
Just one? That might be a good sign to stay away!
For real, though, that was part of the series of mistakes I saw a couple weeks back when I posted about it being an "interesting" summer.
Old 06-17-2021, 01:03 PM   #7
Pricestavern
Pricestavern's Avatar
Default Under-standing
I've gone snorkeling there in the past. Marked for the Mt Washington as far as I can tell. There was no place shallow enough for me to stand (high water); I would avoid it during low water.
The Following User Says Thank You to Pricestavern For This Useful Post:
Hivolt (06-17-2021)
Old 06-17-2021, 01:43 PM   #8
can someone post a picture of the location here from a map?
Old 06-17-2021, 01:49 PM   #9
Default Not just the Mount
Middle Ground Shoals has been on the charts long before the new Mount came to Winni in 1940. Some of the old steamboats were pretty big too. Even today, a deep-vee with a single I/O can draw 3'. Add to that the variation in depth due to wave action, and routine low water late in the season, and it becomes a place to be cautious around. Of course, it might also be great place to drop anchor and relax. No neighbors to make it a NRZ. I don't see a lot of fishing activity in that area, but maybe I just don't go by often enough.
DotRat (06-17-2021), Hivolt (06-17-2021)
Old 06-18-2021, 08:49 AM   #10
Bizer
Bizer's Avatar
Twenty-five years ago, I spent an hour meandering through the area looking for rocks. The shallowest spot I found was four feet down, adjusted for low lake. That would be about five feet down at today's height. But as gwhite13 said, I wouldn't bet my lower unit on that fact. But if you're going into that area at less than one MPH and wearing polarized sunglasses, you should be OK.
The Following 2 Users Say Thank You to Bizer For This Useful Post:
betterthanbacon (06-20-2021), Hivolt (06-18-2021)
Old 06-20-2021, 06:23 PM   #11
JTA
JTA's Avatar
I’ve sailed through there in my Sunfish. No rocks close to the surface, but why risk it?
Old 06-21-2021, 11:15 AM   #12
Hivolt
I posed the original question for fishing purposes, not to bomb through there for the sake of bombing through there.
The Following User Says Thank You to Hivolt For This Useful Post:
Top-Water (06-21-2021)
This page was generated in 0.22197 seconds
