Old 05-29-2020, 02:03 PM   #1
Default Sticking Throttle fix?
My throttle appears to be sticking and NOT operating smoothly.
Mercruiser 4.2 L, Alpha 1 drive (model yr 2000).
When moving the throttle in forward position, it sticks, and almost needs to go past half-way before the engine speeds up ?
Is the issue a 'cable' issue/adjustment, or that the cable needs to be lubed ?
Thanks for your feedback, much appreciated !!!!
Old 06-01-2020, 12:10 PM   #2
My guess is that a cable needs to be replaced, but it may be that the shifter is sloppy or needs lube. If you use the throttle-only button, does it operate smoothly? If so, it's not the throttle cable.
VitaBene (06-02-2020)
Old 06-02-2020, 09:24 AM   #3
brk-lnt
brk-lnt's Avatar
Sounds like a throttle/shift cable issue. Could be rusty inside, kinked, or loose at the clamp near the engine.
[insert witty phrase here]
This page was generated in 0.29759 seconds
