I live in Philadelphia, but I'm planning on coming up to Lake Winnipesaukee in late August to sail my boat. I am also planning to upgrade the boat (MacGregor 26X) with a GPS of some sort.
The question is, what's the best GPS for navigating the lake? I purchased the Bizer chart of the area and I know they also make a chip that will go in certain GPS devices. But I must admit, I am a complete novice at GPS navigation - I've always used chart & compass methods. So, I welcome all your sage advice in this area!!! Thoughts? Cheers, PUFF4 Last edited by Puff4; 05-28-2004 at 02:09 PM. |
I have the Standard Horizon 150C ( color ) with the Bizer C-map chip. The best investment I have made for my boat. I don't use it to plot courses and set way points yet I just use it to tell me where I am and where I shouldn't go. ( I have plenty of people to tell me where to go ) Great unit, it is now discontinued and being replaced with a new upgraded unit. The old ones are on sale pretty cheap while they last
good luck YMMV Charlie |
Yeah, that looks like a good one... I looked on eBay and such and it seems they are reasonably priced now. Do you know what the difference is between that and the newer 155 and 175 units? Seems like the 175 adds a slightly larger screen and detachability, but that's about it.
Have you any negatives at all about the 150C? Cheers, Puff4 |
The Standard Horizons seem to be about the best for the money that use C-Map. If you for some reason decide to get something different, you should know that the only good charts of Winni that are available for GPS right now are available only on C-Map cartridges. So at a minimum, you should look for units which use C-Map cartridges.
Ken |
I use the Hummingbird NS-25 and have had good luck with it. (I do wish it was color.) I have created waypoints and routes from my home to Wolfeboro, Meredith, and Weirs. It's great on thoses dark nights. It also operates on a c-map disk. I also advise that before you purchase any unit make sure a Lake Winnipesaukee disk (like c-map) is available. Otherwise you will have to use a larger regional disk that provides less detail.
I use the Horizon 150 (b&w) and its OK but not good at long distance navigation. As soon as you zoom out, you lose the markers on the map. The colors are not coded correctly for the B&W display, so you can't tell black from red. The marked paths through the tricky parts of the lake are its best feature. Cordinates from Bizer's map (and electronic form) are the most accurate you will find. Using a GPS on the lake is fun. For example, set a course from Weirs to Meredith. Following the course allows you to worry less about catching a rock with your prop, sharpen your GPS skills, and get to see some nice parts of the lake.
-lg |
Puff4
The difference between the new model Standard Horizons and the old ones is a much faster processor - so the redraw times are much faster. Silver Duck |
Thanks for all your input! I think I'm going to see if I can find a 155C - I don't think I need a larger screen, and I'm not sure my cockpit has room for one anyway. As I say, I have a Bizer paper chart and they are wonderful from what I can tell, not being on the lake. So if the C-Map is similar I'm a happy camper!
I just got a flyer from West Marine, and they are offering the CP150C on close-out for $499.99 (after rebates). I've been using the CP150 with Bizer's c-map for a year, and have been very happy.
Interphase Chart Master V6/V6i
Is a new, affordable, c-map based chartplotter. Maybe worth checking out. |
Has anybody heard any reviews on the new Raymarine RC400 that uses Navionics cartography? It looks like a good unit. Has a built in antenna, and detachability.
