06-14-2023, 06:44 AM | #1 |
Not a great thing to wake up to this morning...
...I heard a big noise in the middle of the night during the heavy rains, but assumed it was thunder...I guess not..
06-14-2023, 06:58 AM | #2 |
Yikes! That's weird. I think I see nails but it must not have been attached very well.
06-14-2023, 07:10 AM | #3 |
I'm guessing that pine needles and other debris from the last 14 years blocked whatever drainage it was supposed to have and the water built up and it gave way.
The Following 2 Users Say Thank You to MeredithMan For This Useful Post: | ||
Blue Thunder (06-15-2023), LIforrelaxin (06-14-2023) |
06-14-2023, 07:29 AM | #4 |
06-14-2023, 07:33 AM | #5 |
I can't tell for sure...
But it looks like they used soffit material and nailed directly to purlins attached to the deck joist. The deck joist are beginning to show some signs of rot. They have better systems. |
BroadHopper (06-14-2023) |
06-14-2023, 09:04 AM | #6 |
yes...
Yes, that's exactly how it was done. I am concerned if the joists are showing rot. A few of the deck boards on top have become punky where they get hit with roof water run-off...at a minimum, those need to be replaced. Might be time to bite the bullet and replace the whole darn thing with Azek or other material that will out-live me.
The Following User Says Thank You to MeredithMan For This Useful Post: | ||
coltgov101 (06-19-2023) |
06-14-2023, 09:10 AM | #7 | |
Sorry, friend, but good luck! Sent from my SM-S911U using Tapatalk |
06-14-2023, 09:27 AM | #8 |
Unfortunately the practicality of putting in esthetic features, is often not good. you have to have a way to get that debris out, or the result is as you have experienced..... Hopefully the frame of the deck is still solid.... a few punky boards on top are easy to replace... if you went the "roof" for the deck below, just incorporate a way to pressure wash the debris out occasionally....
BroadHopper (06-16-2023) |
06-14-2023, 10:56 AM | #9 | |
06-14-2023, 11:03 AM | #10 | |
06-14-2023, 11:06 AM | #11 |
''Nail Pop" occurs on both sides of a deck. The expansion/contracting of the wood wicking moisture and then drying out loosens the fastener and allows for a small amount of rot around it.
If the panels are still good... you can check the level of rot... clean it up... add joist tape and reinstall the panels, but with screws that are larger than the current fasteners. Most likely replace the purlins and wrap those with the tape before securing. The top decking can be fixed by a mixture of either deck grates or just replacing a few boards that take the pounding from drip off the roof. (obviously joist tape what you can under those also). Time and Mother Nature will rip down any structure. |
06-14-2023, 12:48 PM | #12 | |
MeredithMan (06-14-2023) |
06-14-2023, 08:51 PM | #13 |
I don't think a hose or pressure washer would work.
The attachment to the purlins limits the gap created for the run-off of water and debris. If you look at a system, like the Trex RainEscape, it creates a large gutter that has an opening deep enough so that all the debris flows freely to the catch basins, and the catch basins are big so less chance of clogging. Just rather expensive. |
06-15-2023, 04:31 AM | #14 |
Count Your Blessings...
MeredithMan (06-15-2023) |
06-15-2023, 07:07 AM | #15 |
You are SO right...
You couldn't be more spot on! When my son is here every few weeks, he and his dog like to sit on that patio furniture below the deck and just look out at the lake. If it had happened when he and the dog were there, we'd have much bigger problems than cleaning up broken vinyl soffit and pine needle sludge.
06-18-2023, 11:09 AM | #16 |
Soffit
Had they used vented soffit instead of solid you probably wouldn't have had this problem !
The Following User Says Thank You to 1helpfulhandyman For This Useful Post: | ||
MeredithMan (06-18-2023) |
06-18-2023, 07:07 PM | #17 |
It would leak onto the patio below... which was what they were most likely trying to avoid.
Prior to decking, you can use Trex RainEscape... after decking you can use Timbertech Dryspace. Other than that... you have to realize wherever the ceiling is attached to the purlin... that is the gap you have for water and debris. Overtime, the purlins will rot, and the nails/screws will release. |
06-24-2023, 04:13 PM | #18 |
Now for the repairs...
OK, so the mess is all cleaned up and now it's time for the repairs. A contractor who was referred to me by a friend came by the other day. I asked for two estimates: one to do the "short-term fix" to get things back to where they were and one that is a long-term solution to replace all of the wood deck boards and rails with Azek or something similar. I also asked him to think about what could be done with the "short term fix" that could prevent this from happening again, (thinking of John's suggestion of the under-deck drainage/gutter system). That was clearly something he had no experience with.
He was a friendly guy, but I just had the gut feeling that this might be beyond his skill-set. So, appreciate any recommendations on high quality, (and yes, that may mean high cost), deck guys. I don't want any hacks and I don't want anyone who does it part-time when they're not working at the fire station. Thanks. |
06-24-2023, 08:47 PM | #19 |
It depends on what you choose.
Are you going to resurface the deck, and is Azek the product of choice? In a perfect world, the contractor would have undergone certification by the manufacturer, know how to use their design tools, and be able to give you what the finished product and price would be before you sign a contract. |
06-24-2023, 10:28 PM | #20 | |
06-29-2023, 06:27 AM | #21 |
Banned
06-30-2023, 07:05 AM | #22 | |
Hopefully, none of the rot has encroached into the sill of the main house. Any carpenter can build a deck. Not all carpenters can build a deck correctly. Trex has an interesting design website. LINK Paul Haskel of Gilford. Name of an excellent carpenter. |
06-30-2023, 10:51 AM | #23 |
Trex has a better one in the deck planner.
But if he wants Azek, he should use the Timbertech one to deal with any nuances of the product line. It will be easier when they go to order as the item codes will match up with the product. |
05-01-2024, 09:22 AM | #24 |
Zip Up
I remembered this thread from Meredithman and thought I would offer this option...
I'm in the process of doing an under deck ceiling system made by "Zip Up". This system is a "do it yourself" system and designed to be installed after your upper deck is installed which makes it nice. It's relatively inexpensive compared to other under deck systems that require access from the top and a lot less complicated to install with only three main pieces required. https://zipupceilings.com/ https://www.youtube.com/watch?v=PGAededTruk The system can accept can style lighting and I decided to go with lights made by Trex which are their "rainscape" can lighting which are lightweight and plug and play and require no electrician to install as long as you have an outlet somewhere to plug in transformer. I ended up purchasing online through Decks Direct as the only place in NH to get it was at Gilford Home Center. Unfortunately they could only get certain colors and sizes that I couldn't use which I thought was a little strange. Decks Direct had everything I needed and shipped it for free and was received in 3 days!! I'll take and post some pics once its done but thus far I have found it to be a pretty easy and good system to install especially for those of you trying to finish off underneath an already completed deck where options are very limited... Dan
05-01-2024, 10:16 AM | #25 |
They may have been looking at DrySpace?
It seems to be a lot more limited in options than the product you chose. |
05-01-2024, 10:50 AM | #26 |
Zipup
Zipup looks like great system. A very nice looking finished project.
25(?) years ago we put a "ceiling" over our lower deck to prevent rain from dripping through. We built a separate 12 x 24 frame and covered with corrugated aluminum panels. It is pitched for normal drainage, but it is also hinged so the whole ceiling lowers for cleaning and we leave it in the down position in the winter which protects the stored furniture a bit. It was a DIY project, but some help and guidance from knowledgeable contractors. |
05-08-2024, 09:14 AM | #27 |
Progress Photos
Here’s a few progress photos…Hopefully complete in the next day or two. Very happy with the zip up system!
The first photo shows the area being worked on. The second photo shows the layout of furring to anchor system to. (crucial) The third photo shows some of some of it completed with lights… There will eventually be a gutter system installed at the end of the system to catch all the water. Dan Don’t know why the second and third pic are sideways???
The Following 2 Users Say Thank You to ishoot308 For This Useful Post: | ||
Descant (05-08-2024), Pine Island Guy (05-09-2024) |
05-08-2024, 11:08 AM | #28 |
Different than the DrySpace.
DrySpace doesn't have any furring strips. The long rails secure directly to the joists and create the required pitch without any measuring... and then the panels between the rails snap in and can be removed at a later date should it need to be cleaned out. The rails protect the wood from rot... but have sizing limits. This is more like our new TrussCore product... but even that one doesn't use furring strips |
05-08-2024, 11:33 AM | #29 | |
Zip Up does sell their own PVC furring but it’s crazy expensive and from everything I researched, most contractors were using pressure treated or other rot resistant wood as furring and I can certainly understand why after doing this project. Just the simple ability to rip your own custom size furring is a real nice benefit! If this space was a simple rectangle and had no lights, this job would take a quarter of the time. While layout is critical no matter what system you use, prepping for lights really consumes time but it’s a must have in my situation. The Trex Rainscape lights are awesome but not cheap! Dan
05-08-2024, 02:54 PM | #30 |
The only reason I hate furring strips is that the water/debris collects next to them were the waterproof panel is attached.
I have been looking to some newer versions were we will have to apply PT ''shims'' the length of the joists to keep the channel clear. Our Trex dealer is working with them... but so new that I have just barely seen a sample today... so not much info or real world experience. |
05-08-2024, 03:01 PM | #31 | |
05-08-2024, 03:04 PM | #32 |
05-08-2024, 04:17 PM | #33 |
To bring this thread full-circle...
...Great to see and hear about your experience with Zip-Up, Dan. I am actually getting that for the repair of what started this whole thread last June...allegedly the project is starting in the next few weeks, so it will be about a full year from the crash to the start of the repair.
To say that this has been a bit of a fiasco is an understatement. Many calls to various contractors who either: a) never showed up; or, b) came out and took measurements and pictures, but then I never heard from them again nor received a quote from them. The 3 finalists who stood out in their professionalism were Scott Compton Builders, and the construction arms of Stephens Landscaping and Miracle Farms. None of these folks are inexpensive, but I was able to see actual jobs they had done and it is all top-notch. Lastly, getting the insurance company to cough up the money was also a back-and-forth hassle and while they are not covering the entire cost, (they deem the Zip-Up system to be an "upgrade" over the original soffit material), they are covering more than half of the cost. Finally, light at the end of the tunnel... |
05-08-2024, 04:51 PM | #34 | |
Good luck with your project! Dan
05-08-2024, 05:12 PM | #35 |
When making major decisions like this, one must always ask themselves. What would John do?
The Following 2 Users Say Thank You to pondguy For This Useful Post: | ||
Biggd (05-09-2024), codeman671 (05-09-2024) |
05-08-2024, 07:54 PM | #36 |
Since I sell the materials to Compton, Stephens, and Miracle Farm... anything they want.
06-23-2024, 02:39 PM | #37 | |
Here some final pics of my completed under deck roofing with gutter completed. Extremely happy with the Zip Up System! Simple install and zero leaks so far! I think you will be very happy with yours…. Dan
brk-lnt (06-24-2024), MeredithMan (06-24-2024) |
06-23-2024, 02:57 PM | #39 |
It is a really nice look... and the specifics of how it goes together looks to be well thought out and durable.
I would like to see more pictures of the gutter detail... That part looks especially interesting. Others that I have seen are bulky and costly. Alex (LaValleys - Gilford) should have information to it... but I like to see actual field installs. |
06-24-2024, 12:50 PM | #40 |
That looks awesome. Thanks for sharing and congrats! We are allegedly starting in a couple weeks, so I'll put up some pix when done.
09-21-2024, 10:34 AM | #41 |
Finally....
Finally done, a year and 3 months after the initial disaster. Had to replace a number of mahogany deckboards that had become punky, as well as some that had completely disintegrated and stain the whole deck. The under-deck Zip-Up system looks great. The carpentry crew from Stephens Landscaping was fabulous. Kept us informed the whole way; very engaging and pleasant to work with; and they kept the whole jobsite immaculate.
ApS (09-26-2024), Irish mist (09-21-2024) |
09-21-2024, 11:10 AM | #42 |
Looks great!! What a difference!
Glad you liked the Zip Up System! Enjoy! Dan
09-26-2024, 10:13 AM | #43 |
Those ceilings look great. I'm sure they weren't cheap. We have a patio under our deck at home and when it rains, it gets wet. I don't really care since we don't want to sit out on the patio on rainy days. Inside is much cozier.
The Following User Says Thank You to retired For This Useful Post: | ||
MeredithMan (09-26-2024) |
09-26-2024, 10:49 AM | #44 |
Thank you
Thank you for the kind words. We don't use that patio area under the deck when it rains, either, but the real benefit of that under-deck ceiling is that it keeps the pine needles and dirt and debris that falls through the deck boards from getting all over the patio. The really neat feature of the Zip-Up system is that the panels "unzip", which allows you to clean out any debris that collects on top of them.
Yesterday, 10:29 AM | #45 |
I get it. What did you use for decking? Ours has 22 year old pressure treated decking that needs constant board replacement and staining. We want to replace it with some kind of composite next year. I looked online at Timbertech, which looks very nice. We are in full sunshine with a southern exposure. The joists are in good shape and are 16 inches on center. Any ideas on what would be a good choice for us?
Yesterday, 01:15 PM | #46 | |
Just sent you a private message. |
