Old 09-08-2023, 01:49 PM   #1
chasedawg
Default Pine sap??
What's with this pine sap? Lived her for 40 years and never can I remember having so much pine sap covering everything. You have to take your shoes off just to go in the house. Our poor dog has pine needles and sap on every paw. With all the rain this year we have had excessive amount of pine needles and now this pine sap. Tried doing some research I learned that it indicates the pine tree health could be a concern. But it is every pine tree. I was in a parking lot yesterday and a car next ours was covered with pine sap. Was it because of the weather this Summer. Great deal of rain, then hot and humid. It started Monday when we had a thick fog. That is when we noticed it . Now has become a sticky problem. Any ideas?
The Following User Says Thank You to chasedawg For This Useful Post:
Dad207 (09-12-2023)
Old 09-08-2023, 02:07 PM   #2
Agree. Best luck I had is with rubbing alcohol. If it’s on exterior house, windows and such. I just let it dry out and scrap it off
Old 09-08-2023, 04:29 PM   #3
Too bad it's not as tasty as maple sap.
Old 09-08-2023, 04:38 PM   #4
joec
Just did a test on a car that was loaded with pine sap all over the windows and paint. We tried Simple Green, Nu Finish car wax, rubbing alcohol and WD 40. WD 40 was the best with rubbing alcohol coming in second.
joec is offline   Reply With Quote
Old 09-08-2023, 04:42 PM   #5
Jeanzb1
What about Goo-Gone?
Jeanzb1 is offline   Reply With Quote
Old 09-08-2023, 05:24 PM   #6
Outdoorsman
for a surface such as a car hood I find Vegetable Oil works best. It seems to wipe clean right away. Then you just have to wash the oil off with soap. So, a 2 step process.
Old 09-08-2023, 05:36 PM   #7
tummyman
Try butter....
Old 09-08-2023, 07:16 PM   #8
NH.Solar
NH.Solar's Avatar
Diesel fuel works better than anything else I Have ever found for cleaning off pine sap. I have a saw mill and normallly use just water with a bit of Pine Sol for that blade cooling drip, but whenever I am sawing fresh pine or hemlock I go with straight diesel. Kinda stinky, but all the machinery glitters like brand new when I wipe it down at the end of the day
Peter
NH Solar
The Following 5 Users Say Thank You to NH.Solar For This Useful Post:
ACME on the Broads (09-13-2023), ApS (09-15-2023), Dad207 (09-12-2023), Descant (09-08-2023), winterharbor59 (09-11-2023)
Old 09-08-2023, 07:32 PM   #9
Now I understand what you have all been saying. Didn’t look at my truck until we went out tonight. WD40 in the morning
Old 09-08-2023, 08:34 PM   #10
The Real BigGuy
I have two big pines right on my driveway where I park. My cars got covered in pitch. I tried everything: pinesol, simple green, assorted other cleaners. Nothing worked. I even found my wife using the edge of a plastic utensil to scrape it off. (Stopped that guck.)
I got rear ended and asked the guy at the body shop what they use. He said they use rubbing alcohol. One cloth with alcohol, one soaked in water.
I started using it and it works great with the exception that there is always some carryover that looks like a haze around the spot you cleaned. I found that if you use a little cleaner wax on the hazed area it takes it right off.
The only real answer is a garage or a car cover. I bought a car cover but my wife wouldn’t put it on. “Too much work”. And using the alcohol & wax isn’t?
Old 09-08-2023, 08:36 PM   #11
That is the best thing in March !
Old 09-08-2023, 08:46 PM   #12
Disinfecting wipes that we all carry in our car these days also work
Old 09-08-2023, 09:09 PM   #13
chachee52
Hand Sanitizer, put a little squirt on the sap, let it sit for a bit, take a paper towel and place it on top and twist it off. Don't rub, it will scuff the paint. Then a little wet cloth to wipe the residue off. Hand sanitizer is mostly all alcohol, but the gel allows it to stay on it without going all over the place.
Works great!!!!
Old 09-08-2023, 11:13 PM   #14
My boat sits under pine trees. his has been a bad year for pitch. Whatever you use, cleaning spots will leave a polka dot appearance so you need to be prepared to do eubbing compound and wax to restore the gelcoat/finish.
Has anybody had a car or boat with ceramic coating? Does that protect from the pine sap?
Old 09-08-2023, 11:31 PM   #15
Jack
Default tree sap
Use straight kerosene!
Jack is offline   Reply With Quote
Old 09-09-2023, 07:40 AM   #16
Winilyme
Yes…a very bad year and all the rain knocks it down as soon as you clean it up. I think it has to do with the abundance of new pinecones on the trees. We get a real bad year every four or five years. Makes a mess of our outdoor furniture and deck. We keep a spray bottle filled with denatured alcohol handy and an old rag. It does a good job removing the sap and the spray bottle makes the process much easier. In a year like this you need to keep up with it nearly every day however.
It’s also been a big year for acorns.
Old 09-09-2023, 08:08 AM   #17
You are right, we have tons of pine cones this year, and lots of sap. I have had good luck with Mr. Clean. It's funny, once it was all over my deck and nothing worked.
Old 09-09-2023, 08:12 AM   #18
I'd be cutting those trees down in a heart beat or at least trimming them back.
Old 09-09-2023, 08:13 AM   #19
LoveLakeLife
We all carry disinfecting wipes around??
The Following User Says Thank You to LoveLakeLife For This Useful Post:
Poor Richard (09-09-2023)
Old 09-09-2023, 08:34 AM   #20
I mean, not in my pocket, but in every vehicle I own, yes.
Old 09-09-2023, 08:51 AM   #21
Susie Cougar
Yes, always some type of wipes or sanitizer.
Old 09-09-2023, 08:51 AM   #22
Been placed in my vehicles for over 20 years. When you work in retail and or sales you shake a few hands and get handed things from others frequently.
Old 09-09-2023, 12:20 PM   #23
Just completed washing and waxing the truck. Alcohol worked the best. Followed it up with a bug and tat clearer
Old 09-09-2023, 04:09 PM   #24
Poor Richard
Poor Richard's Avatar
I'd suggest the following products for pine pitch removal:
WD-40
Sem-Solve
Penetrating oil
No, never. It's pointless. Germs are everywhere. Embrace them.
Old 09-09-2023, 07:32 PM   #25
LoveLakeLife
I like Susie’s posts but I’m with you on this one Richard. Never used such things, never would.
Old 09-10-2023, 04:25 PM   #26
Sweet spot
Default Best for sap
Dawn dishwashing soap works pretty well, but the best thing ever for sap removal - especially from dogs is TecNu. The pharmacist at Hannaford turned me in to it. No smell, no residue and dog does not mind it at all. Works like a charm!
Sweet spot is offline   Reply With Quote
Old 09-10-2023, 05:17 PM   #27
John Mercier
WD-40
Sem-Solve
Penetrating oil
So you don't wash your hands after going the bathroom because it is pointless?
Old 09-10-2023, 06:45 PM   #28
Islandbum
Default Baby oil
When I lived up there I did some tree work on islands. Would come home covered head to toe in sap, we called it pitch.
I would rub Baby Oil all over and wait ten minutes to shower, pitch/sap would glide right off without scrubbing. Smelled good and left skin silky smooth.
Islandbum is offline   Reply With Quote
Old 09-10-2023, 08:56 PM   #29
barndoor
Default Pitch
Dawn and olive oil worked well on my dog’s paws.
barndoor is offline   Reply With Quote
The Following User Says Thank You to barndoor For This Useful Post:
chasedawg (09-13-2023)
Old 09-10-2023, 09:18 PM   #30
Poor Richard
Don't get so easily distracted.
What do you use to remove pine pitch?
Old 09-10-2023, 10:22 PM   #31
John Mercier
Depends on the surface... but painted metal I have used the WD40 method.
My most recent method has been a chainsaw.
Pine trees are of limited value to the cottage. I leave a few on the lower property far from the house for raptors to nest in.
Most of them grow too tall to provide meaningful wind protection that short to medium shrubbery can provide.
Old 09-11-2023, 05:49 AM   #32
TheProfessor
Here.
Having 2 large/tall pine/fur trees to be cut down and removed.
Use rubbing alcohol with white round cotton cosmetic pads on painted areas.
Use razor blade and alcohol on glass areas.
Wash and wax painted areas after.
Old 09-11-2023, 05:30 PM   #33
lakesregionguy
buy a spray can of "bug and tar remover" from Walmart or any auto supply store.
lakesregionguy is offline   Reply With Quote
Old 09-12-2023, 07:13 AM   #34
jeffk
jeffk's Avatar
I just finished cleaning my truck with rubbing alcohol. I made the mistake of parking it under the pine trees overnight. There were a couple hundred drips. The alcohol worked well but you have to keep using clean paper towels. If you don't, the sap from the last blob you cleaned leaves a cloudy smear as you do the next one. Also, don't leave the alcohol on too long, wipe it with a clean paper towel. If it dries with a smear, clean with another clean piece of towel with alcohol and immediately dry again with another dry piece of towel. After I got all the blobs off, I gave it a good wash with regular car wash soap. Today I need to check that I got all the pine pitch off and then wax it.
Even if WD-40 works, it is designed to leave a lubricating film. After getting the pine pitch off, I don't want anything left behind. Rubbing alcohol is designed to evaporate and leave nothing behind. Besides that, I don't want my car smelling like WD-40.
I also had tried Goo Gone which worked but not as easily or with as clean a result as the alcohol.
It seems to me that no matter what you use, it shouldn't be left on the paint surface too long or it could do damage. Perhaps subtle but still compromise the paint/clear coat.
Old 09-12-2023, 09:25 PM   #35
Dad207
Dad207's Avatar
Location: Now residing in Echo Shores, Alton NH, originally from Baltimore MD.
Default Pine Tar / Pitch
This is a great discussion with many helpful suggestions-- I have found that Purell (alcohol-based hand sanitizer) and an old rag, along with some elbow grease, resolves most issues and without residue (e.g. WD 40, diesel or kerosene).
Here is my question: why this year? What is different to make the trees emit so much more pitch? I am baffled, interested in your views.
Dad207 is offline   Reply With Quote
Old 09-12-2023, 09:34 PM   #36
Personal opinion, with all the rain it’s been a terrific growing season?
Dad207 (09-28-2023)
Old 09-13-2023, 08:20 AM   #37
Esp for mushrooms!
Old 09-13-2023, 08:31 AM   #38
Not so great for the vegetables but apparently really great for pine cones and the sap. They glow in the sun.
Old 09-13-2023, 08:36 AM   #39
Agree. Container plants this season were a challenge. Did get some tomatoes and peppers. But, not the bounty we anticipated
Old 09-13-2023, 05:41 PM   #40
chasedawg
Default Pine pitch dogs
That is what out vet said to use for dogs. Olive oil and clean paws with dawn.
Old 09-13-2023, 09:41 PM   #41
John Mercier
Are you using a well draining potting mix?
And what variety of tomato and pepper? And what companion planting did you use?
Old 09-15-2023, 04:53 AM   #42
Wink Turpentine Worked Great!
I took denatured alcohol, xylol, and rubbing alcohol out to the truck's windshield to test on three small patches of pine pitch. (Xylol is what we used to call "paint thinner").
Each worked well, but alcohol cleaned-up best the thin haze left behind. You'll need plenty of rag surface or paper towels. On the paint, I'm going to try out MMO, or Marvel Mystery Oil. (Because I have some handy).
Turpentine is still sold, and is derived from tree sap! Somebody try it out!
White Pine trees are the first species to re-populate a forest after a wildfire. Their ample presence early-on, before logging and farming, had contributed to Lake Winnipesaukee's original clarity. We owe a lot of gratitude to White Pine trees. Their presence lakeside reduces silt, many structures include their lumber, and their twigs start my woodstove's fires.
If you visit a pristine lake nearby, you'll see a majority of White Pine trees. Reach down into the ground covering of pine needles and pull out a divot. You'll see at least an 6-inch depth before the needles deteriorate into a light gray color. Erosion is hard to find.
My steep dirt driveway won't erode when there's an unbroken covering of pine needles. I remove the cones, as they interfere with grip. In the neighborhood, I've even seen a dump truck's delivery of pine needles!
Old 09-15-2023, 05:17 AM   #43
I assume you were the ONE out a hundred who had a perfect garden this year?
Old 09-15-2023, 09:21 AM   #44
Smile
How did this thread go from pine sap to gardening ?
ITD (09-15-2023)
Old 09-15-2023, 09:25 AM   #45
HAHA
Old 09-15-2023, 04:35 PM   #46
John Mercier
Nope.
Only did perennial flowers and shrubs this year.
Clover did well - no pitch.
But it attracts deer. So I was looking to container garden herbs next year... maybe some veggies... but I have never grown in containers.
Just need a different thread for advice on that.
Old 09-15-2023, 04:52 PM   #47
Nope.
My pine needles and pitch shared nicely with my tomatoes which we are still eating- and cukes. And I must have pulled 200 little maple trees out of my containers. But no pine trees. I won't talk any more about the garden so I won't get in trouble.
Old 09-16-2023, 05:05 AM   #48
Made the mistake of resting my bare arm on neighbors mail box while chatting........aarrrgghhhh......covered with pitch.
Brake cleaning spray works well
Old 09-20-2023, 10:00 AM   #49
Triboro
Default Peanut butter
Peanut butter takes pine sap off hands.
Triboro is offline   Reply With Quote
Old 09-21-2023, 08:52 AM   #50
bobkatfly
But what happens when you lick the PB off to clean your fingers?
Bob F
This page was generated in 0.18203 seconds
