Old 06-14-2022, 02:51 PM   #1
Neko
Default Composite decking
What is the best way to clean composite decking ?
Will a pressure washer damage the decking?
Neko is offline   Reply With Quote
Old 06-14-2022, 03:05 PM   #2
If your decking has any wood fiber in it at all, I would not recommend pressure washing it. A scrub brush, soap and hose nozzle would be your safest bet.
If your decking is a solid PVC or some type of solid plastic, you can use a pressure washer with 1500 PSI or less for quick cleaning.
christo1 (06-14-2022), tummyman (06-14-2022)
Old 06-14-2022, 03:52 PM   #3
John Mercier
Hose only.
Soft bristle brush like you would use on your vehicle for areas that might need a bit more scrubbing action. You can use the same detergent that you would use on your vehicle if necessary... but rinse thoroughly.
Pressure washers create micro-abrasions on the various surfaces that will create more issues in the future. Unlike a wood deck, you will not be resurfacing with a stain/sealer.
Old 06-14-2022, 05:47 PM   #4
Neko
I was thinking of using Mold Armor deck, fence, patio wash with a brush.
Would this be OK?
Old 06-14-2022, 06:58 PM   #5
John Mercier
The directions on the Mold Armor will tell you to try it in an inconspicuous place.
But it shouldn't be needed. Mold cannot eat the PVC decks or on the Composite decks that have a ''cap''. On an older style of the uncapped composite, it would be the way to go.
The purpose of the cap on the modern composite decks is to lower the maintenance costs and effort.
You basically need to wash the deck about twice a year... once to remove pollen, and once to remove fall residue (leaves, etc). That ''dirt'' trapped in the ''grain'' of a composite cap is what the mold/moss will try to eat.
While washing them down, the manufacturers suggest to be on the lookout for anything that may signal a future problem.
Old 06-14-2022, 07:31 PM   #6
Neko
Thank you both for your advise.
Old 06-14-2022, 09:34 PM   #7
Typically I use Dawn in a pail of water. Tough stains a spray or two of Spray Nine does wonders. I good brush like mentioned above.
Old 06-15-2022, 09:43 AM   #8
i used a 2700psi pressure washer with one of the circular power sprayer set ups you put on the end of the wand and move it around like a floor sander/buffer
works great and is real fast. I have the original composite decking made mostly out of wood fibers as well
this is the type of attachment i was talking about, there are many different makers out there
https://www.walmart.com/ip/Hyper-Tou...ntent=In-store
Old 06-15-2022, 10:39 AM   #9
John Mercier
Dawn will work because it rinses easily and has very little residue.
Power washing the uncapped with micro-abrasion the material and make the reapplication of the latex stain work. This is the stain designed for uncapped composite decking.
Old 06-15-2022, 11:17 AM   #10
This morning my grandson is washing down our deck, without use of anything but a hose and a wide soft-bristle push broom. That quickly loosens the accumulated tree debris and pine pollen.
Old 06-17-2022, 08:11 AM   #11
Neko
John, Dawn worked great Thanks
Old 06-17-2022, 07:03 PM   #12
John Mercier
SAB1 mentioned the dish soap first.
I used to just sell people Simple Green, but I had an incident where the deck owner did not thoroughly rinse. The rail developed a green tinge were the product had dripped and the water evaporated. I was able to restore the white railings, but realized that best to use a low residue product.
This page was generated in 0.08967 seconds
